Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: advice on dumb stihl oil caps  (Read 2144 times)
Offline yukon72
« on: December 18, 2008, 09:11:01 pm »
Man I am onto my second oil cap for my ms200 in a year. What gives with these things. Any advice on them, Gas cap is fine and works great, bu the oil cap is a real pain in the ass
Offline beenthere
  • EIEIO
Re: advice on dumb stihl oil caps
« Reply #1 on: December 18, 2008, 09:48:17 pm »
Haven't had any problems. Both work the same on the MS361.
Now, forgetting to put one back IS a problem...but my fault.
Maybe the MS200 caps are different, but there is a 'keeper' on mine so they cannot get lost.
Offline Rocky_J
« Reply #2 on: December 18, 2008, 11:14:35 pm »
Leave a little bit of air space instead of filling the tank up to the lip of the filler hole. And yes, they are a royal PITA. Between the overpriced, overengineered gas/oil caps and the phenominal cost of replacement service parts like sprockets and air filters, I pretty much gave up on Stihls except for the 200Ts. I just chalk it up as a cost of doing business and buy extras whenever I have to order one.
Offline sawguy21
« Reply #3 on: December 18, 2008, 11:27:09 pm »
Those caps are a pain in the butt. More than once I have not ensured they are seated then poured gas or chain oil down my pant leg. ::) Make sure to press on tightly then turn so the mark on the cap is aligned with the dimple in the housing.
Offline yukon72
« Reply #4 on: December 19, 2008, 01:05:08 am »
the problem i have is the thing twist somehow and gets allout of sync and then a major pain to get it working again. the locks dont line up and seems impossible to get em to
Offline beenthere
  • EIEIO
« Reply #5 on: December 19, 2008, 01:50:00 am »
Prolly happen to me the next time I go to put them on ::) ::) ::), but so far hasn't happened.
But I did leave the oil cap off once.
Offline OneWithWood
  • showing the past to the future
    • RWT Biodiesel
« Reply #6 on: December 19, 2008, 10:14:17 am »
Be sure you have the tabs lined up in the proper slots.  Each tab is a different size.  And yes, don't fill all the way to the brim.
One With Wood
www.rwtbiodiesel.com
Offline GASoline71
  • 'cuz chicks dig scars...
« Reply #7 on: December 19, 2008, 12:22:55 pm »
I have never had a problem with the Stihl flip style caps.  I honestly don't know what the big deal is...
Gary
\"...if ya mess with the bull... ya gets the horn.\"
Offline WILDSAWMILL
« Reply #8 on: December 21, 2008, 08:17:52 pm »
when i got my 260 pro last year the dealer said people are filling the oil tank full / not leaving air space for the cap to fit & then they break or get out of position to close
the gas cap is vented so it doesent have that problem
Kascosaw2B
Offline rocksnstumps
« Reply #9 on: December 25, 2008, 11:22:43 pm »
I had the same problem with the oil cap falling out on my MS250 last time out. I had to use the scrench to get the bottom part to turn enough to engage the tabs in the saw housing for the rest of the day. Later at home on the bench I took a closer look and found some sawdust trapped between the bottom portion and the flip up handle top piece. Probably a combination of a little bit of oil and the fact that this cap is near the front of the saw with lots of sawdust that causes the issue. Never had the same problem with the gas cap. After using a screwdriver wrapped in a rag to scrap all the crud away, seems the top and bottom portion of the cap "seat" closer together and the problem went away. I was about ready to just buy another one since they're only about $6-7 bucks but now as good as new........still don't like them much however
Offline zackman1801
« Reply #10 on: December 26, 2008, 10:15:58 pm »
my gas caps like to leak, i even switched them over and no dice. oh well.
i have a hard time getting the oil cap to sit tight, it get it in the right spot and then i get it turned and give it a nudge to make sure its seated and it falls off. i do this untill eventually it stays put.
"Improvise, Adapt, OVERCOME!"
Husky 365sp 20" bar
Offline sawcollector
« Reply #11 on: December 27, 2008, 10:15:46 am »
If any style of this cap is pushed in part way and turned without being seated it can get out of index, and to fix it just hold the bottom half and turn the top half counter-clockwise to re-index it correctly. I have seen them get twisted so hard that the top gets turned past the stops and then the cap is ruined.
This is how the cap should look before inserting it into the opening:
If it is out of index position it will look like this, with a gap just above the o-ring:
The oil tanks are worse about getting out of index than the fuel tanks. As has been said, if the oil tank is full to the top, the cap will not go in all the way and if you attempt to turn it while it is only partially in position that is when the trouble starts.
Offline Rocky_J
« Reply #12 on: December 27, 2008, 10:26:26 am »
Leave it to Stihl to engineer and produce a 17 piece gas cap.  ::)
It's almost like the development of this cap was funded and controlled by Congress.  :D
Offline beenthere
  • EIEIO
« Reply #13 on: December 27, 2008, 10:39:18 am »
sawcollector
Thanks for that explanation.
Helps explain why some were having the nightmare problems, and others not having any problems at all.
I'll be checking the manual to see if it comes close to explaining that possible problem.
Offline Rocky_J
« Reply #14 on: December 27, 2008, 11:39:03 am »
Quote
HAH! Good luck with that!  :D :D
Offline stonebroke
« Reply #15 on: December 27, 2008, 11:45:11 am »
What was wrong with the old ones?
Stonebroke
Offline Reddog
« Reply #16 on: December 27, 2008, 12:43:20 pm »
With the old ones. Had to find your scrench most times to loosen them.
The new design is much quicker for refueling and oil.
Just as others have said, if you over fill them.
Offline GASoline71
« Reply #17 on: December 27, 2008, 12:56:52 pm »
Exactly Wally...  Like I said earlier... I like them and have never had a problem with them.
Brian just hates Stihls... LOL...   :D :D :D
Gary
« Reply #18 on: December 27, 2008, 03:05:51 pm »
The marketing folks are the ones who pushed for a "tool-less" cap as something new to spin as a sales feature, and I agree that sometimes the Germans tend to get a little carried away with the engineering stuff, but once you know the trick to getting the cap in place and what to do if it is out of index they are easy to live with.
I went to use the old 009 the other day and I had to use the scrench to get the oil cap loose, then after using the saw a little I was getting oil all over the place since the screwdriver blade had finally gnawed it's way through the slot in that style of cap so I guess it is all relative...
Offline Rocky_J
« Reply #19 on: December 27, 2008, 04:43:19 pm »
I guess I'm the only sawyer in the known universe that never used a scrench on the old caps. If you never tightened them with a scrench, then you never needed a scrench to loosen them. My only problem was if somebody else fueled my saw. They would invariably grab the scrench and torque the cap down to about 350 foot pounds and I'd need nothing short of a cutting torch to get the cap off again. Of course once it was overtightened, then you couldn't just go back to hand tightening it again because the distorted threads would then cause it to come loose.
My solution was to NEVER EVER let anybody else ever get near my fuel and oil caps with a scrench. All Stihl had to do to fix the old caps was to eliminate the screwdriver slot. But NOOOOOOO, they had to 'fix' it.  ::)
Saw Anywhere!
