Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Sawing Short Logs  (Read 3595 times)
Offline Night Raider
Sawing Short Logs
« on: December 10, 2008, 12:27:19 pm »
What is the shortest log easily sawn on a band mill, I was looking at getting a walnut log sawn up that someone is cutting down in the city.  My plan is to be making it into a dining room table so I won't need long board anyway and keeping the logs short will make everything easier for handling.
Offline pigman
Re: Sawing Short Logs
« Reply #1 on: December 10, 2008, 12:45:19 pm »
My standered sawing rates apply to logs 8 ft and longer. I charge by the hour for short logs. I have sawn logs firewood as short as 12 inches, but it is just slow.  The real short logs are sawn by putting a board against the backstops and another under the log if it won't reach two supports.
Online WDH
  • April 1998 - August 2008
« Reply #2 on: December 10, 2008, 12:45:32 pm »
Anything less than 6 feet is a pain on my mill.  My minimum is 8 feet 6 inches.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline blaze83
  • I'm ohio bound
« Reply #3 on: December 10, 2008, 01:26:45 pm »
 Night Rider,
here is a pic of some 4/4  X4'  cherry we cut last spring.  it was pretty easy to do on the LT28......wouldn't want to saw short logs like this for money, but for hobby work it is a good thing i think. Have some 4' walnut and 4' sasafras also. the logs were too crooked to cut at 8' or even 6', and perhaps should have been sawed into firewood. as it turns out me and my dad got about  700bf of cherry 150bf of sasafras and 200bf of walnut. I think it would be well worth the effort for you to cut the stuff into 4'3" or 4'6" logs and then saw it into boards. short boards are pretty too :) guess i'll have to cut firewood out of something else 8) 8)
just my 2 cents
steve
I'm always amazed that no matter how bad i screw up Jesus still loves me
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: December 10, 2008, 01:40:05 pm »
Night Rider;
As already mentioned, short logs take more time to saw!
A lot actually depends on the mill you're going to saw them on!
I have sawn 3' logs on my LT 40 HD and find that it calls for more "attention to detail" than when sawing an 8' log.
The feed rate will usually be much slower and I find that I end up sawing very close to the log-stops or the clamp, than I do when sawing 8' stuff.
In a nutshell, you can saw any length log that you can securely hold with your mills clamping system.  Short ones take longer!
Lots of sawyers will not saw anything under 8'!
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Offline PineNut
« Reply #5 on: December 10, 2008, 03:15:21 pm »
On my Cooks Saw, I can easily cut a 4-foot and with care, a 3-foot log. But I had to add an extra stop and dog. As originally built, an 8-foot log had to be in the perfect position to saw.
« Reply #6 on: December 10, 2008, 03:17:18 pm »
Thanks for the replies.  I figured there wouldn't be any problems just take longer, the guy I'll get to cut these logs charges by the hour anyway, he's a farmer with a band mill, one of many sideline jobs.  I was thinking just under 4 1/2' anyway then I can roll them up the ramp onto my trailer without the meed for much equipment.  I'm also going to try to do something with a crotch to make a coffee table.
Offline SwampDonkey
  • Large Tooth
« Reply #7 on: December 10, 2008, 04:06:01 pm »
I've yet to build anything longer than 4'-6" or if a table is even 8 feet long, most people cut the boards as long as the width, so again about 4'-6" is about all your going to use anyway. If they are your logs, saw them as you like'm or in a way that they can be put into service in your projects.  If walnut is a little hard to come by, or you can use it, or any other tree for that matter, use what you can I say. Heck, it's being severed off the stump to begin with. 8)
Dirty Harry
Offline nas
  • Measure twice and cut aw DanG
« Reply #8 on: December 10, 2008, 05:44:40 pm »
I can cut 4' lengths and am not too far away :)
Nick
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
Offline backwoods sawyer
  • LT-70 proto-type, Cooks AC-36 with edger
    • Backwoods Custom Milling Inc.
« Reply #9 on: December 10, 2008, 09:48:52 pm »
This is a deck of cherry logs that I have been working on for a while now. They are 3’, 4’, and 5’ logs.
It is very time consuming to mill short logs. It can take much longer then milling an 8’ log with half the board footage because they have to be handled all by hand. The difference in the amount of time may warrant the rental of a piece of equipment to load the longer logs. Some sawyers just will not mill short logs even by the hour just because they are a lot more work. Talk with your sawyer and find out if he will mill the short logs and if he will accept help. If you do go with short logs you will be able to save time by providing two helpers so the sawyer can remain at the controls more and positioning logs less.
100% portable. From our Backwoods to yours....
Offline SwampDonkey
  • Large Tooth
« Reply #10 on: December 11, 2008, 08:02:18 am »
Sure can't blame a sawyer for knowing his costs. What I had in mind was the owner of the logs owns the mill and is not sawing any large volume of lumber from short wood. I look at it like a fellow messing with a rare burl or a piece of crotch wood or stump wood. For a sawyer to go around and only saw small short wood he'd have to like volunteer work real well. :D
Dirty Harry
Offline york
« Reply #11 on: December 11, 2008, 08:48:24 am »
I have milled short logs on my TH-blanks for gun stocks-and i will never do it again.....bert
Bert Miller
Offline ely
« Reply #12 on: December 11, 2008, 08:55:07 am »
make sure and figgure in you loss when bucking the logs up short or you may wind up compromising on the lenght of your table.
Offline Dodgy Loner
  • It's an anagram for "dendrology" and in no way a reflection of my personality
« Reply #13 on: December 11, 2008, 09:19:33 am »
Except for me, right? ;D  Remember that apple log that we sawed up?  That was one log that was definitely worth the extra effort!  WDH is right, though- anything less than 6' on an LT15 will require a lot more work.  I've sawn a log as short as 20" on our LT15, but the rarity of the wood made it worthwhile (to me! :)).  By adding an extra clamp in a strategic location, I could make it easier to saw 4' logs, but it may be a while before I get around to that.
The sooner you fall behind, the more time you'll have to catch up.
Wood-Mizer LT-15, 25 HP
Online WDH
« Reply #14 on: December 11, 2008, 09:47:34 am »
I remember.  Some of it ended up in a beautiful table!
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #15 on: December 11, 2008, 12:35:22 pm »
D L  that sure was some good looking wood.  There is a couple of apple trees at my mom's that need to come down.  I may be able to get around to that now that I know what may be inside. ;D  I had an extra stop put on the Cooks when it was made.  Two foot centers on two of the stops, and one of the log dogs hits right in the middle of them.  Tim
Cooks AC 36--Prentice 210C--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
« Reply #16 on: December 11, 2008, 04:06:36 pm »
thanks for the replies, I would need 44" boards so I had figured 4.5' should deal with most of the checking.  This is one of those where a person is having a tree taken down 'sometime soon' but also thinks it's worth what someone would pay at a specialty wood store for it.  I'm not holding my breath, I thought I'd inquire anyway because it could make other things a lot easier in the future.
Nick, you can come mill up a few logs, I'll come up and help you cut some cedar and pine.
thanks for all the help
Offline Dodgy Loner
« Reply #17 on: December 11, 2008, 04:42:09 pm »
Banjo picker, the log in the picture is actually yellowwood, which is a rare tree found in the southern Appalachians and the Ozarks.  The apple tree WDH and I sawed was about 4' long, if I remember correctly.  Don't worry, there's pretty wood inside of those apple trees, too ;).  Here's the table I made from it:
Offline SwampDonkey
  • Large Tooth
« Reply #18 on: December 11, 2008, 05:21:51 pm »
Dodgy, that looks great. How do you keep the bark on? Epoxy?
Dirty Harry
Offline ladylake
« Reply #19 on: December 11, 2008, 08:22:21 pm »
I saw 42" stickers quite often, 8 to15 at a time, no problem with a B20 TK and a setworks that works.  Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Saw Anywhere!
