Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Question for you WM gurus...  (Read 2697 times)
Offline zopi
Re: Question for you WM gurus...
« Reply #20 on: November 12, 2008, 01:51:24 pm »
O- I got over rolling logs around real quick...I've got a 40 hp diesel tractor and a 400 hp diesel truck, the log arch is on the short list. Probably that logrite fetching arch or something similar..I can see
a few other uses for one of those.
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline ARKANSAWYER
  • Poor white Southern trash
« Reply #21 on: November 12, 2008, 01:59:04 pm »
  As for them lasting, mine is close to 10,000 hours and over 2 million bdft.  You may wear out before the mill does.  But they can be fixed and you can get the parts with lots of advice on them.
ARKANSAWYER
Offline woodhick
  • I hope it don't clear off cloudy and come a dry drizzle!
« Reply #22 on: November 12, 2008, 07:15:36 pm »
I started out over 25 years ago with a wore out circle mill.   Sold it when the kids come along.   Went a couple of years without a  mill and the withdrawls got me.  I was still young with a wife and two kids so money was tight.   I built a woodmizer clone.   Worked very well but it was strictly manual just like a LT40 manual mill.   Fast forward to about two years ago.  I leased the homemade mill to a local timber framer.   Well I was going thorugh withdrawls again, so I bought a used LT40 manual from another member here.  He had added some hydraulics to it (clamp, turner).   After I got it I bought the two plane clamp from woodmizer and installed on my mill and built a loader for it.  Mine is basically a LT40HD now minus the toeboards which will come next.   Long story short I would HIIGHLY RECOMEND getting the hydraulic mill!  Did I mention HIGHLY recomend.   I am not looking for high production numbers but the hydraulics just make it so much easier and none of us are getting younger. ;)   Also I can't express how great woodmizers customer service is.  I deal with Marty Parsons of PA woodmizer  and he has helped me out with getting the parts for my mill,  he and Lisa are top notch and I use his resharp for my blades and have not had any problems.
Woodmizer LT40G25, with homemade hydraulics, Nyle L200, and more heavy iron woodworking equipment than I have room for.
Offline customsawyer
  • www.thecustomsawyer.com
« Reply #23 on: November 12, 2008, 08:14:02 pm »
Well since you asked I will tell you. I think the hyd. are important enough that I had WM put them on my 24' ext. I have a extra valve bank just for the ext. I can turn and handle just about any log that comes my way.
I would also ask you to think about the auto clutch if you are going to be sawing full time it won't seem like much at the start of it all but after a whole heep of wood it starts to add up.
Offline LT40HDD51
  • WM Sales & Service for N.S., N.B., P.E.I., NFLD., custom sawmilling in Atlantic Canada
    • Valley Custom Lumber
« Reply #24 on: November 14, 2008, 09:58:37 am »
Personally I graduated from a bare-bones Kubota diesel Super, to a nearly-loaded Cat powered Super in '06.  I was amazed at a few things:
1. The Accuset, especially when sawing odd sizes of stuff, makes every cut go smoother and faster. No creating custom scales or figuring out, say, where to start to cut a cant into full size 1 3/4" stock or something. I had a friend recently who just saw us cut at a show for the first time comment that we look very "smooth" when we saw. I figure that has to be a good thing all around.
2. The Autoclutch both saves the arm big time (heavy diesel), and with the Accuset takes considerably less concentration than the manual handle. By this I mean a flick of two switches and my head is in gear and at the right height for the cut. About a second compared to maybe 5-10 seconds?
3. I like Lube-Mizer, especially when sawing very sticky wood and/or using expensive fluid in the winter time.
4. Debarkers are awesome for lots of dirty logs (but everyones logs are clean, right?).
5. Edgers are awesome (but thats a different story...)
It really boils down to how much you are going to use it. Ive likened it to a car: if you are going to drive it all day every day then you want air, cruise, tilt, etc. A base model is fine for driving once in a while.
For a used mill, I'd echo the two-plane clamp idea. I'd avoid the old Setworks and look for an Accuset or Accuset 2... Im also a big fan of diesels...
The name's Ian. Been a sawyer for 6 years professionally, Dad bought his first mill in '84, I was 2 years old :). Factory trained service tech. as well... Happy to help any way I can...
Offline zopi
« Reply #25 on: November 16, 2008, 05:57:56 pm »
Well, I caught the wife thumbing through the '08 catalog today, and reading WM Way...of course, I >might< have left them in an easily accessible location...
I took my mother in law out today and had her saw a board on the -15..cut a piece out, planed and stained it..gonna have the kids sign it for grandma and varnish it for her...also took a dry pecan flitch and cleaned it up live edged and made a bread board for my father in law...stupid easy christmas present..
The family is enjoying the benefits of having a sawyer kicking around...so I'd imagine once the money comes available I will be in the market..gonna go LT-40 Hydraulic, unless I find a Super in whatever my price range happens to be...
Thanks for all the input, guys..it's not like we don't like talking about our mills...<G>
Got Wood?
And lots of junk.
Offline ED B
« Reply #26 on: January 22, 2009, 12:56:03 pm »
Control is great. It really helps in turning logs. It also gives you a table for your first cuts. The only way to go! A debarker is equally as important
Do It With WOOD!
Saw Anywhere!
