Get your Forestry Forum Hats while they last!
If you want fast accelleration, get the 346xp, it revs up much faster than the 5100 - but don't run it on part throttle - "blipping" is the right way on small twigs.
Takes two buds for my hands to stop shaking
....That said, there are times when I run the throttle full open as well as there are times when I may run them with the throttle just under full open without bogging down or lugging the saw. I think the problem with running at half throttle would be one of engine cooling as the flywheel is not moving as much air across the jug and the load on the saw would cause it to run hotter. More RPM more air flow to cool the engine.Just a theroy at this point. Randy
