Get your Forestry Forum Hats while they last!
I think it's set up pretty good right now. Maybe drop back to a 16" bar if you prefer it over the 18"You really could go either way on the chain pitch, 3/8 would work fine too. It would be a personal preference choice.
I like it with 16" 3/8 7T and full chisel. Since you need a new bar and chains, check the drum and replace the sprocket to 3/8's and your on your way.
Quote from: Ed on October 02, 2008, 01:41:39 pmI think it's set up pretty good right now. Maybe drop back to a 16" bar if you prefer it over the 18"You really could go either way on the chain pitch, 3/8 would work fine too. It would be a personal preference choice.Is one set-up more suited to hardwoods, or more suited to larger or smaller diameters than the other?
By 'clutch removal tool', do you mean an old screwdriver and a hammer, along with some spare starter cord to use as a piston stop? Do some reading in some of the older threads, unless you are completely mechanically inept then you probably already have what you need and the ability to do it yourself.
.....Still curious as to what kinds of applications I'd want to run a 7 vs 8 tooth sprocket on a 357xp with a 16" bar.John Mc
Thanks for all the advice, guys. I'm going with a 7T and 3/8 to start with. I am going to take SawTroll's advice, and pick up an 8T as well, so I can see for myself what the difference is.John Mc
