BID ON A FORUM AUCTION!
Hey SwampDonkey : would the shagbark hiuckory grow up here My book says,(for whats thats worth) range would be extreme southern Quebec You are probably in the same boat as me with your buckeyes, so lets try....Let me know how many you want....Just a few horsechesnuts for me...will send a PM...Tim
Obviously, you finally found some butternut trees. They elude you no more. That's unless you tell me someone else found them.
Wouldn't mind trying some butternut down here in the foothills in Forsyth County.
All my butternuts here are dead or dying . I have some smaller ones , but it seams that as soon as they mature ... dead dey go ....
Marcel, only if you obtain the seed from neighboring states like Northern NY, Northern PA and northern Michigan and southeastern Ontario. Seed from the southern states and southern half of those bordering the lakes would not do to well. Goes for most hickories.
Banjo picker:. Scorching summer heat and drought may be a factor to as well as length of day. Doesn't hurt to try.
Maybe I can make an arrowhead out of the flint you're sending, and in a few years I'll make a hickory bow from the hickory nuts you're sending
