Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Garwood winch  (Read 17289 times)
Offline Tom_Averwater
  • Semi- retired Carpenter
Garwood winch
« on: September 12, 2008, 09:21:21 pm »
I have a Garwood 10,000 lb. winch that I would like to use on my 4610 Ford tractor .I would use the hydraulics on the tractor to power it.What speed do these winches run ? How big of a hydraulic motor would I need to run it?  Thanks Tom
He who dies with the most toys wins .
Offline pineywoods
Re: Garwood winch
« Reply #1 on: September 12, 2008, 10:09:11 pm »
Tom I have a big ole Koenig winch mounted on the 3 pt hitch on my kubota.I used a chain drive to a moderate sized hydraulic motor. You can use different sized sprockets to adjust the speed.  It will easily skid the 5000lb tractor with the brakes locked.
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline timberfaller390
Re: Garwood winch
« Reply #2 on: September 12, 2008, 10:23:21 pm »
you probably don't want to pull anything faster than walking speed (about2-3 MPH)
Appalachian Hardwoods Lumber and Logging Co.
Peavine Valley Farms
Three Notch Forge Farrier Service
Stihl MS390
John Deere 5103
58 IHC A-162 log truck
Offline thecfarm
Re: Garwood winch
« Reply #3 on: September 13, 2008, 04:38:35 am »
I would suggest having the controls for the winch on a rope so you can keep away from the tractor and winch when winching in.Have the winch stop when you release the rope.Alot of junk can come at you at times.Are you going to have the winch hooked up to the 3PTH to allow it to be lowered and raised?Could make a skid plate for it.Can be used to push logs around,but I like it to keep the tractor in place when winching.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline mike_van
Re: Garwood winch
« Reply #4 on: September 13, 2008, 07:58:21 am »
Tom, I built mine some 10 years ago using a Tulsa winch from a wrecker. I powered it with a hyd. motor, but was never really happy with how it ran. The IH 574 has a 12 gpm pump, but 3 gal are diverted for steering, brakes, etc. By the time you get through the plumbing, valve, etc, there might be 7 gpm at the remotes?  It ran pretty slow, if a log hung up, it would just stall. I had it for sale for awhile, a few lookers but no takers at 500.00  -  A few weeks ago, I put it in my shop, and after much thought, converted it to pto drive. The hyd motor had 200 rpm, now I have 540 if I want it. The power level increase is hard to believe. I pulled two 40' logs last week, both about 18", from 200' away [close as I could get] They came through some rosebush - honeysuckle jungle you couldn't walk through. One hung up in the bank when it came out, tried to pull the rest of the way with the tractor, but the wheels spun. Moved ahead 25', set up again, the winch pulled it right up & over.  One drawback is I no longer have a power reverse, so you can't put yourself where you can't back up to let the tension off if need be.  I've got a job soon with over 50 cord of locust to pull out, so it'll be a good test.  Oh, I'm real happy it didn't sell.
Offline WH_Conley
    • Stone Hill Hardwoods
Re: Garwood winch
« Reply #5 on: September 13, 2008, 09:36:06 am »
I have a Braden winch that I set like Mike did, with hydraulics. Also like Mike, it is now straight PTO. Just don't put it behind a stump to pull something big, if the drag gets behind another stump you are in trouble.
Tom, if you want to make a road trip you can come and look at my setup, we'll hook it up and you can see what it will do.
Bill
Offline John Mc
Re: Garwood winch
« Reply #6 on: September 13, 2008, 10:23:31 pm »
That's about the speed the Farmi Logging winches will pull.
Small time fire-wooder in a neighborhood cooperative.
Offline shinnlinger
Re: Garwood winch
« Reply #7 on: September 14, 2008, 08:04:47 am »
I like the idea of PTO power, and since weight and space isn't ussually an issue on the back of a tractor, could you put an auto tranny in there so you have reverse???  Isn't there some forward / reverse gearboxes out there?
Shinnlinger
Woodshop teacher, chicken farmer
34 horse kubota L-2850, Turner Band Mill, '52 GMC Dumptruck,
living in self-built timberframe home
Offline John Mc
Re: Garwood winch
« Reply #8 on: September 14, 2008, 08:40:43 am »
Do you actually need a powered reverse, or just a release? Something to let it freewheel would probably be easier to come up with. For that matter, some tractors PTOs are not locked in position when the PTO is shut off. Would that give enough of a release to get out of a trouble spot?
Offline mike_van
Re: Garwood winch
« Reply #9 on: September 14, 2008, 09:10:37 am »
I don't think a clutch or reverse is a 'gotta have', but it would be nice to have the option. My winch has 2 dog type clutches on the right side of the drum, in the picture where the lever is. You pull this to freewheel the drum & run out cable. With a good strain on it, I doubt you could pull that lever.
       My pto, it's an independant one, won't freewheel more than one turn, even with the tractor off.  The worm drive winches tend to be self locking, the ring gear won't drive the pinion.  Just to try it, the first tree I winched out, i pulled it up too far - With tension on the cable, I was able to just pop the pto shaft off the back of the tractor, and turn it backwards by hand, it let the strain right off.  Just something I'll have to learn to live with -
Offline arojay
Re: Garwood winch
« Reply #10 on: September 14, 2008, 09:16:56 am »
If you are going to set up some kind of freewheel, you must have a brake.  If you suck up on something and go straight to freewheel you will spend the rest of the day unravelling cable.
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
Offline markct
Re: Garwood winch
« Reply #11 on: September 14, 2008, 07:50:37 pm »
thats an interesting setup mike, just yesterday i made up a mount for a simular size holmes winch i had to mount it on the 3pt of our little ford NAA. its mechanical and has the freeweel as well as a forward and reverse incorporated into its gearbox so it was a simple matter of putting together a short pto shaft and then adding a long lever for the forward and reverse that i could reach from the tractor seat. across the bottom i put a large piece of angle iron to help dig in the ground and hold it in place when pulling. it will get its first test sometime this week dragging and loading some of the ash logs i got from a friends lot.
Offline John Mc
Re: Garwood winch
« Reply #12 on: September 14, 2008, 09:06:44 pm »
... then adding a long lever for the forward and reverse that i could reach from the tractor seat
If you are operating it from the seat, I hope you've got some sort of safety screen or something to hide behind. A cable can do a lot of damage if it breaks under load.
Offline markct
Re: Garwood winch
« Reply #13 on: September 14, 2008, 09:15:33 pm »
yea unfourtanatly to be able to run the clutch of the tractor thats where i gota be, but i do plan to put some sorta screen on eventualy, basicly this is sorta a quick throw together thing to avoid having to do so much work with a come along and to be able to have a bit better control pulling logs on the truck than we get with just driving the tractor along with the cable thru a snatch block since 1st gear isnt as slow as i would like when guiding a log with a bar! so no real hard pulls, and most of the time will be running thru a snatch block on the truck or yarding point to if the cable came unhooked from a log that should stop it before the hook end got to me, but still something to be cautious with indeed
Offline mike_van
Re: Garwood winch
« Reply #14 on: September 15, 2008, 06:04:06 am »
Mark, the guard I made on mine, you can see in this pic. 2" angle with expanded metal mesh. It could probably be bigger, but it's easy to add on to.
  That fwd/N/rev on your winch is good, I saw another like it a few days ago.
Offline pineywoods
Re: Garwood winch
« Reply #15 on: September 15, 2008, 10:28:59 am »
pto vs hydraulic drive...   Go with the hydraulic if at all possible. You will need reverse/power out more often than you think. with ptoThink log hung on a root, cable tight as a fiddle string, no way to loosen it. Well, you can put the pto in neutral and get on the drive shaft with a pipe wrench  smiley_furious3 Don't need all that big a hydraulic pump or motor. I have snapped 1/2 steel cable with mine. 9gpm pump on a kubota.  with pto, you have a short drive shaft with some severe angles on the U joints. they will fail often. with pto you have no safety fuse. When something hangs, the weakest link will break, hopefully not the drive gears in the tractor tranny or the worm gear in the winch.  expensive :o Hydraulics will have a pressure relief that gives some protection. In either case, one other thing to keep in mind.....those old winches are worm drive, running in an oil bath. The worm needs to be immersed in oil, splash lube ain't good enough. So don't mount the winch with the input shaft on top. I ain't saying how I know :-X
Offline dancan
  • Even when i'm not busy i'm busy.
Re: Garwood winch
« Reply #16 on: September 15, 2008, 07:53:29 pm »
Good reading and insight .
I bought a similar winch with the same intentions of mounting on a pto .
What were the original uses of these winches
(Image hidden from quote, click to view.)      -
Offline pineywoods
Re: Garwood winch
« Reply #17 on: September 15, 2008, 08:23:26 pm »
re--original uses for these winches....Around here, every oil-field truck had one of these mounted right behind the cab. roller chain drive down to a shaft which ran underneath the truck to a pto on the side of the transmission. Usually a boom made from 3 pieces of oil-well pipe with a snatch block on top. Used for loading, unloading and setting up drilling equipment, and as a small general purpose crane.
Offline dancan
Re: Garwood winch
« Reply #18 on: September 15, 2008, 08:35:56 pm »
It's the load/tension thing that made me wonder , how was tension released in it's original application ?
Offline pineywoods
Re: Garwood winch
« Reply #19 on: September 15, 2008, 08:52:17 pm »
pto's on most truck trannys are reversible.
Saw Anywhere!
