Get your Forestry Forum Hats while they last!
My brother sells automated strapping machines, and he tells me the plastic strapping is stronger and safer than steel. It's all they use and a lot of their machines are used in the steel and lumber industries.
Quote from: red on August 01, 2009, 10:43:27 amI just heard of a Web Strapping Kit from www.kubinecstrapping.com and Baileys Sells it just wondering if anyone has tried it yet RED Yep. I was sold after the first bundle I made.For the last several years my client would collect the slabs and edgings in half-cord bundles and strap them with half-inch metal strapping. He'd flog these off as cheap firewood.Now that I'm buying logs myself, I have to deal with waste. I decided to try the Bailey's kit rather than invest in an expensive and heavy steel strapping system. I figured for a $100 it was worth a try. Here's my observations:1) The manual tightener was intended for square packages rather than round bundles. However, I've been able to get it to work for me on my slab bundles.2) The 250' rolls of banding are light enough to carry (Bailey's includes a bag) so you can tighten up a load and then cut the strapping. With metal I pretty much had to precut all my straps in the shop, then take them to the site.3) If you cut the strapping just past the bottom of the manual tool, you'll have enough slack to retighten the load. No extra buckle required -- just pull the strap tighter. With metal you have to have enough overlap to get your tensioning tool in place, re-tighten the load, and add another clip.4) The Bailey's kit literally gives you everything you need. Just carry the bag to the job site and go to it .Am I going to stick with the system? For sure. I expect I'll buy the buckles by the 1000 as there's a significant saving. But I'm going to keep buying the 250' rolls of banding -- the 2 x 1650' rolls only save you half a cent per foot and are a heck of a lot heavier.
