Author Topic: Diesel engine and bio diesel  (Read 4081 times)
Offline artenvielfalt
  • sawmiller carpenter distributor
« on: August 05, 2008, 06:46:22 am »
hi there, maybe it is the fastes way and others see it too,
i have a 10" with a 24 hp Honda on it and a wide frame for 1,5m cutts. is it possible to change the engine to a diesel one?  or what is done to the frame that it is stronger? have you pictures for me.  and does the engine run on biodiesel yet,... it might be a very good option to do that so it saves a lot of costs for the fuel
what is the change on the gearbox?
thanks and till soon
ulf
Offline techmark
  • Tech Support at Peterson Sawmills
Re: Diesel engine and bio diesel
« Reply #1 on: August 06, 2008, 12:39:05 am »
Hi Ulf,
It is possible to convert your 10" mill to diesel.
We are using a reasonably lightweight aircooled diesel, so the frame does not require additional strengthening, it does need some big rubber engine mounts to help damp the vibrations. You can use your existing gearbox.
The diesel engine can run on B10 (10% biodiesel)
i will try and get some photos
Mark.
Offline thecfarm
« Reply #2 on: August 06, 2008, 09:28:47 am »
techmark,go up to help and read on how to post pictures.I see you made up an album.You are proably hung up on sizing the pictures correctly.Give us a yollar.We will gladly help you.There is alot to it,but it is easy to do once you have done it a few times.
Offline techmark
« Reply #3 on: August 06, 2008, 04:15:53 pm »
ok, so this photo is a bit of a test.  :)
If it works and you guys want to see more, let me know.
Offline techmark
« Reply #4 on: August 06, 2008, 04:25:06 pm »
phew it worked   ;D
Offline submarinesailor
  • LT15 and a wife of 41 yrs
« Reply #5 on: August 08, 2008, 10:26:53 pm »
Yes, we want more pictures........
Bruce
Offline techmark
« Reply #6 on: August 10, 2008, 07:33:45 pm »
I shall get some more photos shortly, when we are building the next order. In the meantime there are some shots of the diesel mill in action on this thread here
