Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Cutting hollow trees  (Read 2671 times)
Offline Good Feller
« on: July 12, 2008, 10:47:29 pm »
I haven't had much experience cutting down hollow trees.  What is the best approach?  Is there any difference between cutting down "live" hollow trees and "dead" ones?  Thanks
Good Feller
Offline zackman1801
Re: Cutting hollow trees
« Reply #1 on: July 13, 2008, 12:24:03 am »
you have to be carefull of dead ones because you cant leave any holding wood if you bore cut , because it might not be sturdy. also wedges arent a good idea especially if the tree is really dead because you could break the top right off.
"Improvise, Adapt, OVERCOME!"
Husky 365sp 20" bar
Offline Maineloggerkid
  • Earth first...Log the other planets later!
« Reply #2 on: July 13, 2008, 05:50:43 am »
IT depends how dead they are. IF they are still sturdy, I cut them like a normal tree, if the are like jello, I find the lean and let them go the way they want to. Widow makers aren't anything to mess with.-Be safe when cutting.
JD 540D cable skidder, and 2 huskies- just right.
Loggers- Saving the world from the wrath of trees!
Offline Kevin
    • The Milling Masters
« Reply #3 on: July 13, 2008, 08:41:29 am »
Dead trees are most dangerous.
There can be problems with the holding wood, overhead branches and tops breaking out.
I've pulled them and cut them.
If the tops hit anything they can easily break off and come right back at you.
Live hollow trees can be cut with a shallow face usually.
Offline Phorester
  • Can't have a healthy forest without cutting trees.
    • About Forestry Forum Host
« Reply #4 on: July 13, 2008, 09:03:28 am »
Most of my tree cutting is confined to forest fires.  Naturally, we cut a lot of dead and half dead trees since they're also burning, might burn, or did burn and might again.  But......, we "cut" them with a bulldozer whenever possible.  Point being that they are dangerous, burning or not, and we don't stick a chainsaw into them if we can get them down with heavy equipment.
About.Forestry.Com forum host. Ya'll come: http://forestry.about.com/mpboards.htm
Offline Rick Alger
« Reply #5 on: July 13, 2008, 10:26:01 am »
I agree with the advice above. Shallow face, shortish   back cut, and  a machine with a cage to push it over.
Lacking a machine I knock down  the dead ones  with a live one -  from a fair distance away.
Offline rebocardo
  • Atlanta GA
« Reply #6 on: July 13, 2008, 01:28:02 pm »
On many trees, especially hollow ones, I wrap the trunk with chain above where I am cutting. If possible I get a cable up into it and shake the tree if dead to remove any widow makers and if the top is coming down, I want it down before I start cutting.
Middle of the woods, I would wrap it in chain if possible, cut with the lean with a shallow face cut, and cut the back cut as quick as possible before gravity takes effect. Then get back and give it a minute or two to fall.
I tend to cut high on hollow trees because less rot the higher you get and I do not want to be bent over with my head near the trunk and want to be able to run easily. Plus, I do not walk around the tree, I try to get my face cut from the same side of the tree as the back cut. One it is much faster. Walking takes time and standing directly behind a hollow tree that might barber chair or come apart enough to jump the stump is something I avoid.  Cutting your notch from the same side as the back cut, since you are cutting with the top of our bar, is not for everyone ...
The worse thing, imho, about hollow trees is when it sits on your saw while doing the notch.
Offline Good Feller
« Reply #7 on: July 13, 2008, 11:17:44 pm »
So shallow face cut.  Then what?  Bore cut to the back OR cut from the back towards the hinge,,, does it matter?  I've cut down lot's of trees but none that were very hollow.... just want to do it safely when I come across this situation.
Good Feller
Offline Kevin
« Reply #8 on: July 14, 2008, 07:18:19 am »
There's usually nothing to bore on a hollow tree, the middle is already gone although there's no rule that says you can't bore to set up the hinge wood.
On rotten trees there isn't any fiber that's strong enough to split out so that wouldn't be any concern either but each tree is different and every precaution should be taken to control the fall of the tree and staying safe when doing so.
Offline Bro. Noble
« Reply #9 on: July 14, 2008, 10:33:21 am »
Why would you want to cut a hollow tree,  unless close to your house or other buildings?  When we are cutting logs and I hit a hollow space while notching a tree,  I move on to the next tree unless I feel the hollow one is an immediate hazard.  If I drop it,  it's using time that doesn't earn anything,  it's often risky,  and it will do just as much damage to surrounding young timber as a good tree.  If left (preferably girdled)  the limbs will drop straight down when they fall and do little damage to surrounding trees.  The hollow tree provides habitat for wildlife and is no competition to surrounding trees if it is dead.
I know this isn't an answer to the question that was asked.  There have been good answers on how to take the trees down,  I just thought that leaving the tree should be considered where possible.
Offline Ron Scott
    • Ron Scotts Web
« Reply #10 on: July 14, 2008, 11:52:44 am »
Yes, they provide den, snag, and cavity trees for wildlife. Note the "Animal Inn" thread.
~Ron
« Reply #11 on: July 14, 2008, 12:07:18 pm »
They make a good drum for talking to your neighbors in the next village too.  ;D
Offline Bro. Noble
« Reply #12 on: July 14, 2008, 05:10:09 pm »
Well,  Tom,  that's really a moot point------unless you are on thumping terms with your neighbors in the next village. ;)
Offline Engineer
    • BLAZE Design Inc
« Reply #13 on: July 14, 2008, 06:18:49 pm »
Sometimes you don't know they're hollow until you're into them.  I dropped a large white birch that was standing dead, and only until I notched it did I realize that it was hollow and I wouldn't get a good hinge (and it was leaning too, but in the direction of the notch).  I bore-cut each side to the back, and then cut the holding wood last.  It dropped clean, but could have easily shifted off the stump and dropped as much as 90 degrees to the notch.
Very dangerous to cut hollow trees, they are best left alone unless you NEED to take them down.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
R. J. Wiedemann LtCol. USMC Ret.
« Reply #14 on: July 14, 2008, 07:34:24 pm »
The reason I would take one down would be for safety.  Some of them have too little good wood to leave them stand.  Since you never know when a wind might come along and send it to the ground, you might be under it at that time and get squashed.
Br'er Noble!   I'm on thumping terms with a lot of them.  As a matter of fact, I know a thumper up there in the middle of Michigan. ;D
Offline rebocardo
  • Atlanta GA
« Reply #15 on: July 15, 2008, 12:00:03 am »
Myself, I would avoid bore cutting a hollow tree. Things can fall on the saw from the middle of the tree such as the punky middle. With 500+ pounds jammed on your bar about the only thing you can do is remove the saw head. Plus, things animals have deposited into the hollow can fall or you can hit it with the saw and dull the chain, you can cover yourself in wet smelly punk, a sheet of bark can fall from the outside of the tree onto the saw, the tree can simply split into many parts like a barber chair, etc.
 MSOP is to use enough back cut until I see movement or hear a crack then wait for it to fall from a safe distance OR to cut the back cut extremely fast to where I think it should make it fall and then move quickly before it comes down completely.
imho, The most dangerous part are dead branches or the top splitting at a upper crotch and coming down and killing you. I cut a pine tree that was dead and leaning, not even hollow, and when it started to fall, it broke into pieces. The two separate good long pieces came straight down and basically fell either straight down or backwards while the trunk went were it should.
Could have easily killed me if I had not gotten out of Dodge and had stood around looking at the tree, doing a fancy bore cut, pounding wedges, etc.
I would say on dead or hollow trees, cut them which ever way you feel best doing them, but, when that hollow tree starts to fall, make sure you are far away, behind a hardwood if possible.
From my gallary
"barberchair saved by wrapping chain around trunk"
This counts as a true hollow tree
"part of a tree that barberchaired and was saved by wrapping with chains and cables. This part was wrapped with 1/4 cable."
I do not know if I could call it a "barberchair", more like crumble or split apart.   :D
Offline zackman1801
« Reply #16 on: July 15, 2008, 12:27:51 am »
sometimes if the trees have been dead and standing for awhile they get hard, at this stage they make decent firewood. and if your luck when it hits the ground i will split itself. although if you have a choice stay away from them or if you can knock em over with a skidder or tractor, that is if they are small enough.
Husky 365sp 20" bar
Offline tomtrees
« Reply #17 on: July 15, 2008, 06:56:27 am »
If they are realy rotten they can just collapse as soon as you put the saw in "not nice". The other thing is that they often dont go in the direction you want. Being a tree surgeon I some times get take downs like this. I either put a big price on the job hoping that some one else will go in lower or forget to quote.
Offline Kevin
« Reply #18 on: July 15, 2008, 07:18:41 am »
This red oak got the bore cut to set up the hinge.
Offline rebocardo
  • Atlanta GA
« Reply #19 on: July 15, 2008, 03:14:30 pm »
Nice looking tree  :D
Saw Anywhere!
