Get your Forestry Forum Hats while they last!
Read the angle from the plumb bob string on the protractor. Now you have the hypotenuse and one angle. The plug in calculator will now give you the vertical leg of the triangle.
Do you have a hose long enough? Fill a hose at the pond level, and put a pressure gauge at the source level. Devide pressure by .434 that will give you head in feet.Dave
OK. I've been there. Without the instruments, how do you figure the angle I'm thinking there is a stick kinda thing, that a Forester can use, to gauge the height of a tree. Can't remember it's name or where I saw one described
