Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: husky 346xp, stihl MS280 & 260  (Read 7646 times)
Offline chugbug
« on: June 04, 2008, 08:17:12 pm »
Stay with me guys , I'm learning alot here and I know you have been through this before , but I think I have it narrowed down to these 3 saws . They all have about the same 50.1 C.I. except the 280 is listed at 54.7. And there all in the same weight range , 346 is 11 pds. the ms 280 is 11.7 and the ms 260 is 10.6 . I think someone said the ms280 isn't in the same class ( not being a professional saw ) so it might not be a fair comparison as I believe the husky 346xp and the stihl ms260 are both pro saws , so which one would you pick ???
Offline Urbicide
Re: husky 346xp, stihl MS280 & 260
« Reply #1 on: June 04, 2008, 09:37:48 pm »
You are correct about the MS-260  & the 346XP NE being pro saws. I have a 346XP NE. It is has become one of my favorite saws. I have not run a MS-260 so I can't really comment on it. (Btw, all Stihl pro saws, with the exception of the MS-200T, have white handles).
The "classic" 346XP was basically designed as a high speed limbing saw. The New Edition version is a much better over all saw. It is easily destinguished from the older version by its silver colored clutch cover.
One other saw you might want to look at is the Dolmar 5100S.
Offline chugbug
« Reply #2 on: June 04, 2008, 10:30:00 pm »
Do you feel the 346 or the 260 would make a good overall firewood saw ?? I cut smaller stuff around the house maybe up to 12'' and whatever I get on a tri-axle load of oak   .Weight is a big factor for me , to give you some info my old saw is 13 1/2 pounds with bar and chain and I can handle that fine .I never had an up to date fast cutting saw and want to do it right the first time .I think I could narrow it down to either the new husky 346xp or the stihl ms260 and it sounds like the husky has more up to date anti vib and is a little cheaper , everyone seems to think the 260 is a little behind the times .
Offline Urbicide
« Reply #3 on: June 04, 2008, 11:57:37 pm »
Either saw will fit your needs. My 346XP NE is pretty much my go to saw. If I know I am going to need something a bit bigger then I grab my EHP 359 or my EHP 372XP.
One thing I would recommend for you. If you get the Husqvarna and it has a catalytic muffler (will have a green fuel cap and say e tech on the recoil housing) replace it with a stock, non e tech version (non EPA). The reason being the catalyst produces a ton of heat and since it is attached to the cylinder it will not permit it to cool properly. It is a virtual heat magnet. A new muffler should run around $35 to $40. It will also give a bit more performance too since it is not as restrictive.
Offline SawTroll
« Reply #4 on: June 05, 2008, 03:56:39 pm »
No-brainer really - the Husky is a much better saw than either Stihl.
I have a weak spot for the ol' 260, but not weak enough to buy one.....
Btw, the Husky cost a lot more than either Stihl here - I still didn't have the slightest doubt about buying one..... 8) 8)
Firewood saws: Jonsereds Raket 621 (1970), Husky 353G, Stihl MS361W, Husky 372xpg, New Edition Husky 339xp, Dolmar PS5100SH, New Edition Husky 346xpg, Jonsered 2153WH, Husky 560xpg.
Offline chugbug
« Reply #5 on: June 05, 2008, 06:01:47 pm »
Hey guys , I stopped in at the stihl dealer today and got to hold the 260 ,  its a very nice handling saw , none of the home owner self adjusting junk on it , not very much at all to go wrong on the outside , self oiling , no manuel ( hope thats ok) does have the side chain adjust screw where its easy to get at and only 10.6 pds in weight . I didn't come home with it yet ,I still want to see the husky 346xp .
 Saw troll , what do you like about the husky so much more than the 260 ??, I'm sure the husky has more anti vibe but I won't be running it all day so thats not a huge factor, what else is the 260 lacking !!
Offline SawTroll
« Reply #6 on: June 05, 2008, 06:50:09 pm »
Compared to the NE346xp - air filtration, anti-vibe, throttle responce and power.....
Offline chugbug
« Reply #7 on: June 05, 2008, 09:51:43 pm »
OK Sawtroll ,I'll check out the husky as soon as I can and see how it feels , thanks for the help . Wish there was some place you could run them and really get a feel and see how they cut !!! So far I haven't been able to find any of are local loggers using either saw . Jonsereds seems to be used quite a bit because they like the dealer , I no there basically the same as the husky . The jonsered  I saw this week  had the primer bulb , it just seems like a week spot to me . But I did like the compression release , man that saw was easy to pull and the release turned off by itself.
Offline NYH1
« Reply #8 on: June 07, 2008, 12:29:21 am »
chugbug, if you have good Johnny Red support in your area, see if you can check out a 2153.  It's pretty much the same saw as the NE 346XP, different front handle bar angles and color.  For some reason they list it has having a tad less power then the NE 346XP, I don't know why.
My NE 346XP has a 16 inch bar and 21LP (H21) chain.  It flat out rips.  A 2153 should do pretty much the same.
I would definitely look at a 2153 or NE 346XP.
Husky 365 20" b&c
Husky NE 346XP 16" b&c
Stihl 021 14" b&c
Offline SawTroll
« Reply #9 on: June 07, 2008, 09:02:25 am »
Welcome here!! 8) 8)
...and you are right.... :)
Offline NYH1
« Reply #10 on: June 08, 2008, 12:43:57 am »
Thanks SawTroll! ;D
Husky 365 20" b&c
Stihl 021 14" b&c
Offline jokers
  • Chainsaw Freak
« Reply #11 on: June 08, 2008, 09:02:38 am »
The 2153, just as the Husky 353, is ported differently and does have less peak horsepower than the 346 but a wider powerband. I`d recommend the 353 or the 2153 over the 346, even the new edition 346 to the average guy cutting firewood.
I`d also suggest that chugbug not rule out the 280 too quickly if the price is right. I owned for a long term demo and found it to be a very nice saw with decent power and torque for it`s weight, quite a bit more torque than any of the saws being discussed here. It was a good enough saw that I had no qualms about selling it to a friend who I see fequently. He`s ecstatic about it but his prior experience was with a Poulan and an ms290.
Offline SawTroll
« Reply #12 on: June 08, 2008, 03:43:50 pm »
Russ, it looks like you mix up the 2152 and the 2153 - the 2152 is the 353, and the 2153 the NE346xp.............. ;)
Offline chugbug
« Reply #13 on: June 08, 2008, 09:08:47 pm »
Don't have a johnny red  dealer very close but maybe one hour  away , Have a husky dealer much closer , are there any differences or are they identical saws ?? I will see how much less the 280 is , but I think someone said they weren't made anymore . Is ther any chance the johnny red hasn't been updated like the husky 346xp with the newer 50 cc engine .
Offline jokers
  • Chainsaw Freak
« Reply #14 on: June 08, 2008, 10:16:34 pm »
Yes, you`re right SawTroll! The 2153 has less power because it is red.........or maybe because that`s how the Husky marketers like it to be perceived.  ;)  :D
Offline SawTroll
« Reply #15 on: June 09, 2008, 02:26:55 am »
If it is a 2153 it is the new one - the old 346xp is the 2147 when it is a Jonsered.
Offline SawTroll
« Reply #16 on: June 09, 2008, 02:33:15 am »
Yes the power rating is a tad less on the Jonsered - it is with some other models as well, and vice versa with the 2159 vs. 359.
I believe it is just marketing.......... ::)
I stay with the Husky versions anyway, mostly because of the handlebar angle, even though the Jred ones looks better.
Offline NYH1
« Reply #17 on: June 09, 2008, 01:59:18 pm »
I feel the same way.  Plus in my experience, the Johnny Red's cost more then the equivalent Husky's.  In my area the 2153 cost $50 to $60 more then the NE 346XP.
Husky 365 20" b&c
Stihl 021 14" b&c
Offline dancan
  • Even when i'm not busy i'm busy.
« Reply #18 on: June 09, 2008, 07:32:16 pm »
I've not cut any 12"oak but have blocked alot of 10''+ spruce and maple and have found that the bigger saw = less time working , if i was going to rely on 1 saw I'd be looking at the Makita6401/Dolmar5100 or the stihl MS361(my preference ;))
Offline chugbug
« Reply #19 on: June 09, 2008, 10:15:27 pm »
Thanks for the advise , I have a larger saw for cutting big stuff , but find a heavy saw is just to hard on my back especially when cutting odds and ends up in the woods , this saw will replace my old homelite super ez , so I was trying to stay in that weight class 14 - 15 pds , I see that the big saw might work ok for cutting up the oak I got from the tri-axle load as I'm not bending over as much and like you said its quicker . I can't wait though to see the difference in these smaller saws compared to my big old homelite VI955 , I'm thinking the new much faster saws might cut faster even though they don't have the horsepower .
Saw Anywhere!
