Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Gang rip saws, build or buy?  (Read 3139 times)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« on: May 09, 2008, 06:46:16 pm »
I keep running into the same conundrum regarding ripping boards down for various purposes. I make a lot of stickers, usually saw out boards on the mill and  put them back on and rip them to size. Same for battens. How available are gang rip saws, and how adjustable are they? I'm thinking an arbor that I can put an assortment of blades and spacers on to get the widths I need might work just fine. What kind of blades do you need for this kind of operation? Thanks.
Dave
Wood-Mizer LT40HDD51 Wireless, Kubota L48, Honda Rincon 650, TJ208 G-S, and a 60"LogRite!
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: Gang rip saws, build or buy?
« Reply #1 on: May 09, 2008, 06:56:42 pm »
 I bought a dozen Carbide tipped blades for my friend here. He bought a "Made" gang rip, and I had to do some adjusting on it, so it would feed straight. Here's a couple pics.
  This is built in a shop down here. Not exactly the type of factory you are used to seeing in the States. Not really a big deal to make, but, there are many factories-sawmills shutting down in the states.
  Probably buy one much cheaper than building, time wise.
  Have you ever checked out Talladega Machine Sales ???  It's a place like Sawmill Exchange. Google it.
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
« Reply #2 on: May 11, 2008, 03:29:00 pm »
http://www.irsauctions.com/index.asp
Look at view past auctions for past prices (just saw a weinig u17 moulder go for $3500)
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
Offline Sawyerfortyish
  • Bigger they are the more mess they make
« Reply #3 on: May 12, 2008, 06:24:08 am »
I have a 642 cornell edger. It edges on the left side of the mandrell with 3 blades 2 of them move and I have a gang bank of 4 blades on the right side of the mandrell set for cutting 2" battens. I use carbide blades. It doesn't take long to rip out 100 battens for barn siding.
Offline Woodchuck53
« Reply #4 on: May 23, 2008, 04:37:46 am »
Morning Dave. I have 2 edgers. One with 4 fixed blades and one with the sliding adjustment from 4" to 22",  I think. I just got it in a swap type deal. Wouldn't an edger set like this fixed one work for your size ops. The fixed edger is really old and set for 2 4" passes and 1 6" size. I haven't set it up yet but will probably use it seperate with an electric motor on it. The variable one is driven off the flat pulley behind my v-belt drive of the main motor. I hope to get some pics. of it soon. How's the surge deck???  coming along?  CV
Case 1030 w/ Ford FEL, NH 3930 w/Ford FEL, Ford 801 backhoe/loader, TMC 4000# forklift, Stihl 090G-60" bar, 039AV, and 038, Corley 52" circle saw, 15" AMT planer Corley edger, F-350 1 ton, Ford 8000, 20' deck for loader and hauling, F-800 40' bucket truck, C60 Chevy 6 yd. dump truck.
    • My homepage
« Reply #5 on: May 23, 2008, 05:27:02 pm »
My thoughts on building a gang rip would be to have infinite adjustment by changing out spacers, to get the widths I need. I also want to do it in one pass, which means I need a bunch of blades, and a bunch of horsepower. I'm in no rush for this at the moment. Going to be making some stickers next week, will stand boards up on the mill as usual.
Surge deck is going slowly. Waiting on a repair for my bandsaw. I don't like to do fabrication without it.
Dave
Offline David Freed
    • Freed Hardwoods
« Reply #6 on: May 25, 2008, 10:05:23 am »
You can take a look at my photos for one more option. It works great for me, but it will only cut 6/4 or thinner.
    • My homepage
« Reply #7 on: January 09, 2010, 02:09:02 pm »
I've been thinking about this again fairly seriously. I have a number of different products that I need to rip down, and I think it is too slow to do on the mill. I've seen machines for sale that would do what I want, but they are pretty darn expensive. I can build most of it here, and I have access to lathe and milling services. To continue on with the design stage, I need to get some information on blades.
Specifics are:
Blade type, i.e. carbide, serviceable vs. disposable.
Thickness of body in .001"s as well as actual kerf in .001"s
Size of arbor. It looks like the arbor in FDHs pic is quite robust. I assume that is to compensate for the cantilever of the shaft.
Any leads on suppliers of blades, as well as opinions on blades would be a big help and greatly appreciated. Thanks. I'm going to check our sponsors and see what they offer as well. :)
edit: I see some blades have splines and some don't. I'd like to avoid having to spline the arbor. Any input on that aspect would be appreciated as well.
Offline red oaks lumber
« Reply #8 on: January 09, 2010, 04:06:53 pm »
dave,
 google gang ripsaws  there are plenty of used ones, go with one that a dip chain most have mandrels with spacers for different widhts, super easy to change sizes.
 i bought a used one 3 yrs ago for $5,000 14" wide variuble speed upto 200 fpm.when we make stickers i stack the blades at 1"spacing and start ripping 1x8 out the other end comes 7-1"stickes at 80fpm it doesn't take long to have a pile of sticks
my favorite color is   clear
    • My homepage
« Reply #9 on: January 09, 2010, 05:29:10 pm »
I'm not sure I understand the part about the dip chain. What is that? This is going to be a do it yourself project. I don't have, or want, to spend out of pocket for this. However, I do have a lot of iron and odd parts, as well as access to the machining. It will take some time, but I'd have to get paid and awful lot to make it worth buying a complete machine. I have a friend that is retiring soon, and has set up a very nice little machine shop. He is always looking for new challenges, and also wants a timber frame shed, which is within my capabilities. I'm thinking a trade might be in the works.
« Reply #10 on: January 09, 2010, 05:43:04 pm »
sorry dave i thought you were looking to buy one. can't offer any advice on building one other than be careful! the wood feeding in will want to be kicked back at you
    • My homepage
« Reply #11 on: January 11, 2010, 06:53:05 pm »
I've found a couple of blades offered online. The ones with a big arbor have a 70mm hole(2.7559"). That seems like it would work on a 2.750 shaft, unless I need less than .006" free play. If anyone has a gang saw, I'd be interested to know what type of blades you use, and what, if any, type of keying the arbor uses.
red oaks lumber, what type of blades does your rip use? How many HP is the saw? Thanks.
I've got my machinest and my mechanical engineer consultant on board for this project.
Offline Reddog
« Reply #12 on: January 11, 2010, 07:40:57 pm »
Yep that seems like the right clearances.
« Reply #13 on: January 11, 2010, 08:10:55 pm »
dave,
 there 12" dia. .125 thick 3" bore  40 tooth carbide  smooth bore. my gang rip has 50 hp
 when buying blades you need to specify they are for ripping, the teeth are groung differently, i think the ends are ground square but, i don't know for sure.
 i would go smooth bore versus keyed bore, over time your keyways will get very sloopy, smooth bore is a commpression squeeze with a big nut keeping it tight.
 my gang has 2 rows of anti kickback fingers, keep that in mind when building asaw, ripping dry wood is a very violent operation stuff will explode inside the saw housing, like i said before everything wants to kick back towards the infeed side
    • My homepage
« Reply #14 on: January 11, 2010, 09:22:54 pm »
Thanks Reddog.
red oaks, I appreciate the advice. I will certainly make some sort of anti kickback device. I know how badly a table saw can kick back and have the bruise to prove it. Don't want to be on the receiving end of 25 or more HP. :o I was hoping a smooth bore setup would be acceptable, as that is how I want to set it up. It will also be much easier to make. I found a website that offers a variety of saw blades and some specifications. I guess I can call them when it comes time to choose a blade. I'm hoping they can advise how much HP per blade as well as type of blade for my application. I will be ripping ash and oak into sticker and stake blanks. I am somewhat limited by my genset. Hoping to stay around 20-25 hp to leave room for blowers and drive motors. I'm not worried if it won't run at 200 fpm, anything will be faster than a table saw. :D
« Reply #15 on: January 11, 2010, 10:07:12 pm »
for what it's worth.. when we run 8 blades ripping dry oak running 80fpm it's drawing 60amps. so i think you won't need anymore than 20hp just have your feed slower.
« Reply #16 on: January 12, 2010, 12:36:56 pm »
 This info does NOT concern a sponsor, but, I bought the 12 blades for my Buddy, from BH Payne. Look them up, call and talk to Bobby Richardson, and maybe he can pull up my invoice, to tell you what I bought. I gave the Invoice to my Buddy, and his Accountant has it.  ::) ::)
  The blades get used ALL the time. They are Carbide tipped, and not 1 of them has had a problem, sawing soft through VERY hard woods.
    • My homepage
« Reply #17 on: January 12, 2010, 12:50:37 pm »
Thanks FDH. I'm now searching for pillow block bearings. MSC stops at 2". smiley_headscratch.
« Reply #18 on: January 12, 2010, 01:33:08 pm »
 Try an outfit like Corley Sawmills. The one I had used a standard 2 & 7/16 shaft dia. IF I remember correctly ??? Might be overkill ???  Try a heavy Equipment Garage. They use big shafts or an AG garage, like Cat-Deere- Case-, etc ???
  Just checked
http://www.surpluscenter.com Pillow Blocks to 3" or 35 MM ???  8)
    • My homepage
« Reply #19 on: January 12, 2010, 02:00:15 pm »
At those prices, I can have a couple of spares. Thanks. Will have to figure out the arbor a little more to find out what size bearing we need.
Saw Anywhere!
