Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Using E85 In Your Sawmill  (Read 2491 times)
Offline GF
    • Twisted Oak Sawmill
« on: May 08, 2008, 08:44:42 am »
Some of the fuel stations around my area have been selling E10 fuel without notifying the customers.  I filled my sawmill engine up with E10 the other day and noticed it did not run quit as smooth and seem to burn much more.  I was not aware the fuel I had put in it had ethanol in it until I had someone test it.  The pumps I used to fill the containers were not marked as having ethanol.   I was wondering if anyone else has ran into this?
Home built bandsaw sawmill with 31hp v-twin, Cooks Catclaw Sharpener, Cooks dual tooth setter, John Deere tractor, 35 ton splitter, and home built firewood processor.
Offline york
Re: Using E85 In Your Sawmill
« Reply #1 on: May 08, 2008, 09:54:30 am »
 GF-just looked at your link-what is your mill????thanks,Bert
Bert Miller
Offline beenthere
  • EIEIO
« Reply #2 on: May 08, 2008, 10:01:17 am »
GF
How did you "have someone check it"...??
Fortunately, we have a Mobil station in town with no ethanol added....don't know for how long tho.
Offline stonebroke
« Reply #3 on: May 08, 2008, 10:06:14 am »
If they sold you E85 without telling you and did not give you a price break I would say they are committing fraud.
Stonebroke
Offline flip
  • The Nations WOOD Capital
« Reply #4 on: May 08, 2008, 10:06:27 am »
No but your findings are typical.  A lot of stations are using up to 15% ethanol in the "regular" stuff.  Do not be surprised if you start to develop some leaks or seeps in your carb or fuel system, ethanol is hard on some seals and gaskets.
Unrelated but since the govt. made everyone switch to low sulpher diesel we have see a lot of 7.3 diesels with fuel drain valve leaks.  We contribute it to the 2 orings on the valve being incompatible with what ever filler they are using in place of the sulpher.
Hope all turns out well.
It's easy to see if you have E85, put some in a mason jar and take a wif, smells more like alcohol than gasoline.
Timberking B-20, Hydraulics make me board quick
« Reply #5 on: May 08, 2008, 12:08:23 pm »
The wife called me from town last night, all miffed that Hess had put alcohol in the gas.  The price didn't reflect it and the sign was an added tag on the pump where she didn't see it until after she had pumped a half of a tank.   She quit.
I'm wondering what it will do to the older cars that frequent the station.  Mine is probably OK, being a 2005, but there are a lot of vintage autos that use that station.
Offline GF
« Reply #6 on: May 08, 2008, 12:37:31 pm »
A majority if not all the Wal-Mart (Murpheys) in Oklahoma use E85, until someone brought to the attention of the public via the news no one was aware of this, now they have an E85 sticker on the pump.
My sister has a Camry and used regular gas it got 34MPG with gas, when she filled up at Wal-Mart her milage went to 27MPG.  Driving the same way to work everyday to compare them.
According to the Oklahoma law currently they can sell E85 and not have to let anyone know.
The E85 gas is the same price as the normal gas.
Offline GF
« Reply #7 on: May 08, 2008, 12:41:49 pm »
Real question now is they are not telling us they are putting ethanol in the E85, are they exceeding the 15% ethanol?   I am guessing they are putting more than 15%.
Offline wudhed
    • Woodhenge Timberframes L.L.C.
« Reply #8 on: May 08, 2008, 01:00:17 pm »
E85 will also do bad things to the valvetrain in your engine. Since it contains alcohol it burns hotter and will burn up your valves and seats. If your vehicle isnt set up for E85 its bad news!
 The E85 that is available to us here in the states is a joke! Corn is the very worst thing that you can get ethanol from. There is an ethanol plant in Brazil (i think) that uses sugar cane it puts out way more ethanol than corn and htey use the leftovers to power the plant that makes it as well as a small community several miles down the road. You get way less milage from E85 then regular gas or even gas with 10% ethanol in it. One of my employee's has a newer Chevy truck that is flexfuel and he says that the milage suffers considerably when he uses E85.
Proudly building quality timberframes since 1981!
Offline Toolman
  • "DONT TREAD ON ME"
« Reply #9 on: May 08, 2008, 01:09:20 pm »
Its an incredible case of fraud and it's legal. I've been adding 1 oz. synthetic motor oil to ULSD fuel for every 10 gal. fuel for lubricity plus 3 oz. 99% pure acetone every 10 gal. For Gasoline same amounts plus Xylenol(1 oz).It works, been doing this for over 3 yrs. with excellent results. High fuel efficiency and cleaner running engine. The problem with ethanol,among many, is that water does not seperate in alcohol and is carried through your system resulting in much lower BTU. In regular fuel water settles to bottom, not with alcohol, it is carried along right to your injectors. Moon Shine in your fuel tank is a bad idea. Check out Brightgreen.com  interesting facts concerning this.
"A government big enough to give you everything you want, is strong enough to take everything you have" (Thomas Jefferson)
Offline flip
« Reply #10 on: May 08, 2008, 03:30:25 pm »
We do see people come in/call in with sudden drops in fuel economy 10-20%.  The fuel companies, at least in this area, use a winter blend and summer blend.  Don't ask me whys or where's, I don't know if it is state mandated or federal or what.  The fuel economy anomoly will last for a few weeks then things will be ok for a while.  I don't think they have to tell you what % of ethanol is blended in as long as it is under 20%.
From our experience in cars, you WILL notice an economy and performance difference, usually it is a loss of 20-25%.  I would not run over 20% in anything that is not flex fuel or e85 compatible, it's just a waste.
Offline GF
« Reply #11 on: May 08, 2008, 04:06:15 pm »
Nothing like paying the same price for E85 fuel compared to normal fuel with a decrease of 10-20% in milage.
E85
    3.50 Gallon @ 27MPG = 12.9 Cents Per Mile
Gas
    3.50 Gallon @ 34MPG = 10.3 Cents Per Mile
According to my math there is no cost benefit to the consumer.
« Reply #12 on: May 08, 2008, 05:37:05 pm »
Quote
As consciencous as the stores make you  believe that they are, I don't know of any who have the consumer in mind when they make these "business" decisions.  They just want your money and will put hands in all four pockets if they can.
Fuel prices haven't anything to do with the quantity of oil in the ground, only with what has been made available to the consumer.  The addition of alcohol has nothing to do with economy or ecology, only profit at the pump.
Fuel manufacturers from the well drillers to the retailers have a captured audience.  They know you have to have it and only two things will control the price, price restrictions by the Government and consumer pressure.  The Government has already shown that it doesn't want anything to do with price at the pump, so that leaves us.  Until we refuse to buy the stuff, they will get away with doing what they want.
If you had control of all of the air, what would you charge? :)
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #13 on: May 08, 2008, 06:19:42 pm »
alcohol actually burns cooler than gasoline, and requires more fuel/engine stroke to balance the combustion cycle.  This is why fuel mileage is lower.  If you are properly compensating for the alcohol, you may see a very slight increase in HP.
lots of dull bands and chains
Offline Haytrader
« Reply #14 on: May 08, 2008, 07:52:20 pm »
My nephew put some Ethenol in my mill and we won't do that again. It does not run as well and there is what looks like dirt in the tank. That means the fuel filter will probably clog up sooner.
URRRRRRRRRRRRRRRRGG!!!
Haytrader
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #15 on: May 08, 2008, 07:56:10 pm »
 Cain't GET dirt from Ethanol. Had to be from the container it was held in.
Offline Luckyfarmer
« Reply #16 on: May 08, 2008, 08:06:33 pm »
I have a 07 GMC flex fuel, it gets 2 or 3 less milage but I buy it for .50 cheaper.  Thats $15.00 savings per tank..I am all for this
Offline brdmkr
  • I need to slow down...
« Reply #17 on: May 08, 2008, 08:16:44 pm »
Word is that if you can find e85 it is about 70 cents/gallon cheaper in GA.  I have an E85 truck that I would like to run on E85.  I was told by the dealer that I could expect 15% less mileage.
Offline GF
« Reply #18 on: May 08, 2008, 09:38:25 pm »
E85 in Oklahoma is the same price as normal gas, all stations here advertise E85 with no cost cut.
Tom, I could not agree more.
Quote
Also the fuel companies know it has effects on seals and gaskets, it maybe a good opportunity in the near future to file a class action lawsuit against the oil companies on behalf of all the citizens of the US, for the billions in profits they keep getting.  The only way to get their attention is to start getting their money.
Offline Haytrader
« Reply #19 on: May 08, 2008, 10:34:33 pm »
Harold,
Didn't say it was dirt. Said it LOOKED like dirt.
I brought this to my nephews attention and he said it was part of the corn gas. He said thge local Co-op was getting a lot of complaints and quit ordering it.
So far it has caused no problems with the mill. I guess it is just staying on the bottom of the tank.
Haytrader
Saw Anywhere!
