idle is 2930 and full throttle is 12540. i adjusted it first by following madsens carb tuning like you advised. now the taching. i did back the low down a little after i put the tach on but it seems to struggle a bit when i do so i put it back up to 2900's. i have not touched the high though. do yo think that 12540 is a good high end or should i adjust it to get max. an if i do that am i risking the engine?
