Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Small Kiln  (Read 3137 times)
Offline sawwood
Small Kiln
« on: February 16, 2008, 08:05:16 pm »
 Was looking on the outher forum and seen a link for plans for a small kiln. Though you
 might like to see.
  Lester
http://dnr.wi.gov/forestry/publications/pdf/FR-396-2007.pdf
Norwood M4 manual mill, Solar Kiln,
Offline Osagedon
Re: Small Kiln
« Reply #1 on: February 17, 2008, 07:31:13 pm »
Thanks for the link Sawwood.  Nice kiln
                                           Don
Offline MikeH
    • treefaller
Re: Small Kiln
« Reply #2 on: February 17, 2008, 07:51:43 pm »
 Very nice, we need more small kiln's around. ???
Offline zopi
Re: Small Kiln
« Reply #3 on: February 17, 2008, 09:46:17 pm »
that's pretty cool...funny, they seem to have used lumber from a lumberyard instead of sawmill boards...i'm sure there is reason..but it is ironic... ;D
Seems like that'd be the thing for a woodworker to have tucked into a lean to off the workshop...needs to be at least 4 feet
longer tho... ;)
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline shopteacher
  • Hiking Sedona, AZ.
Re: Small Kiln
« Reply #4 on: February 18, 2008, 11:58:28 am »
I was thinking along the same line as Zopi.  Looks like a big portion of the cost is in lumber. I would surely use my own.  It is a nice set of plans though. Thanks Les
Offline Brian_Rhoad
Re: Small Kiln
« Reply #5 on: February 18, 2008, 01:01:01 pm »
I think that kiln was built by a college or trade school. They probably didn't have rough cut lumber available.
Offline rfalk
    • My webpage
Re: Small Kiln
« Reply #6 on: February 18, 2008, 08:05:56 pm »
This DH design evolved out of the American Woodworker Magazine design and was built at Madison Area Technical College (MATC) in cooperation with the USDA Forest Products Lab (Rick Bergman, drying expert) the Wisconsin Department of Natural Resources (Terry Mace, wood extension specialist), and the University of Wisconsin Forestry Dept (Scott Bowe, Professor). Bergman has run several loads of lumber through it and has data and recommendations on drying of various species in this unit. A paper should be coming out soon with those results. I will share with the forum when available.
Bob Falk, USDA Forest Products Lab
Wood engineer, woodworker, chainsaw miller, bandsaw miller, all around lover of wood.
Stihl 026, 361, 076 AV
Offline Larry
Re: Small Kiln
« Reply #7 on: February 18, 2008, 08:34:21 pm »
Bob, the plan is both well thought out and documented.  Unless I missed it, they did not mention the size of DH that was used.  I look forward to seeing documentation of the results.
A little off topic...I have searched for plans to build a hot water kiln using a wood-fired outdoor boiler such as the Central Boiler unit...zero results.  Any ideas on where to look for plans?
Larry
Nine out of ten trees recommend wood for your building project.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Small Kiln
« Reply #8 on: February 18, 2008, 10:19:37 pm »
I'm also interested in the type of space heater that was used.  any information on that?
lots of dull bands and chains
Offline Handy Andy
  • Location: right on the edge of the great american desert
  • I'm not new anymore
Re: Small Kiln
« Reply #9 on: February 19, 2008, 05:21:56 am »
  Thought I read something about baseboard heater?  But they didn't give any btu's.
My name's Jim, I like wood.
Offline Kelvin
Re: Small Kiln
« Reply #10 on: February 20, 2008, 08:55:27 am »
Whats interesting is when i built my own homemade kiln with DH unit and sealed electric oil heater type the heater never came on.  THe waste heat from DH unit and fans kept it up.  Same with my new Nyle 400 The heater hardly ever comes on and i often have to dump the heat in winter even.  I guess its there to get the temps up for the DH unit.  Also i found that my DH unit wasn't even working in my homemade job.  I don't think they handle the high temps.  What was happening was my chamber was so leaky that the water was leaving thru the cracks and condensing onto the floor.  I think the temps killed my DH unit pretty quick, this is why Nyle uses commercial DH unit in their operation as they are designed for high temps.  I havne't seen the plans above as i have dial up, but maybe they made some accomodations for this.  Also, doesn't oak eat any metal?  Are they stainless?  How long will they last?  I buy mine used at garage sales, so i guess i can just keep putting in new ones, but i was amazed at how well it worked with bascially no DH, but only heat from the machine, leaving thru cracks in the chamber.  Not how i planned it, but it worked.
KP
Offline rfalk
    • My webpage
Re: Small Kiln
« Reply #11 on: February 20, 2008, 11:34:32 pm »
They used a home dehumidifier, from Sears, I think...about $200 new....any home unit will work. There have been many threads discussing the required dehumidifier...consensus seems to be that any cheap unit works fine...if it wears out or corrodes, buy a new one. I'm not sure about supplemental heat....I will have to ask what was used. Some on this forum have suggested using an old window AC unit as it will condense while providing heat from the compressor...seems a good idea.
I can't speak to the hot water boiler design....will ask as see what I can find out. Cheers, Bob
Offline sawwood
Re: Small Kiln
« Reply #12 on: February 23, 2008, 09:53:46 pm »
 After reading a lot on DH kilns i have a few question. I am going to build the small kiln
 and i want to git the right Dehumidifier. From what i have read looks like i need a unit
 with 1.5hp and work in high temps. But how much water can it remove is what i don't
 understand. Can some one let me know what i need for this 500bf kiln. Also i will be
 loading it with air dried oak and walnut. I plan on useing a wall elect heater to control
 the heat needed. I think with our own cut lumber and i have two fans out of a overhead
 furnace 1/3hp 14" all we will need is the plywood and insulation. this should help keep the
 cost down
 Lester
Offline bck
Re: Small Kiln
« Reply #13 on: February 24, 2008, 04:54:49 pm »
Kelvin , I also have dial up . I opened file, then left for 20 or 30 minutes , when I came back it had downloaded and was readable. I did this on the other forum its on but should work here too.
Offline sawwood
Re: Small Kiln
« Reply #14 on: March 16, 2008, 09:41:47 pm »
 Bob any new on the small kiln at the wisconsin forestry dept ? I still would like to know what size DH unit to use and if a small wall heater was used what size. We are still in the
cold weather pattern here in KC so would like to know soon so i can start looking for
the equipment to install when we have the kiln built.
Lester
Offline james04
Re: Small Kiln
« Reply #15 on: March 17, 2008, 09:11:51 am »
I have just completed building a variation of this kiln. I got the DH from Waly World. It is a Sharp/LG.Cost was $179.  Seems that Sears,HD also carry the Sharp/LG. Only the one at HD has a five year where the Sears and WM version have a 1/5 years.The compressor is the only part with the five year. Also got a heater that looks just like the one in the photo. $12 at the Big Orange (HD). End of season sale. Original price was $39. I will let you know how I make out once things get started. 600BF of Red Oak starting today.
Does anyone know how operators of these home DH kilns are able to get the temp up to 120 or more? I am sure the thermostat on the heater will shut off well before anything that high. Also does anyone know what temp is needed to kill mold spores. Or even if that is possible.
James
Offline Ironwood
    • http://www.branchandburl.com
Re: Small Kiln
« Reply #16 on: March 17, 2008, 01:53:05 pm »
James to my knowlege (limited) you need steam to kill spores, temp alone will not do it. My experience with DH kilns is, depending on how much insulation temps can easily get that high. I put supplimetal baseboards on my ceiling connected to a separate thermostat to get the temp up REALLY high to sterilize.
        Ironwood
Offline ohsoloco
  • Can we stay outside and play in the sawdust?
Re: Small Kiln
« Reply #17 on: March 17, 2008, 02:29:31 pm »
I still have the issue of American Woodworker with that kiln in it.  Most of the heat came from the DH unit, and there was also a light bulb (150 watt incandescent, I believe) to give supplemental heat as needed  :P
Offline shopteacher
Re: Small Kiln
« Reply #18 on: March 17, 2008, 02:31:40 pm »
ohsoloco do you have the issue number of the FW magazine?  I looked for that article and haven't been able to locate it.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: Small Kiln
« Reply #19 on: March 17, 2008, 03:29:14 pm »
 It's American Woodworker, issue #94. June 2002, page 42.  ;) :)
Saw Anywhere!
