Get your Forestry Forum Hats while they last!
Avgas from your local small airport. Alcohol is an absolute no-no
The feds control the specs for aviation fuel, NOT the states or locals. True avgas is 100 octane with small amount of lead. commonly known s 100LowLead. Some airports may stock and sell automotive gas to be used in some older aircraft, but it can't contain alcohol. Alcohol corrodes the aluminum fuel tanks and lines. Plus it tends to absorb water, which will freeze at high altitudes even in summer weather. Either situation could ruin your whole day.
I run it a few years ago prolly 10 now . I asked the other trainer what was hin his saws as the smell had give me a headache . Run just like my saws but with a stink. and the fuel stayed good.
pineywoods - what is the going rate for some of this liquid gold? I imagine it can't be cheap
Here in NW Oregon, I could get alcohol regular during the summer, so have stockpiled a few gallons.
The tech. at the local saw shop is mixing 3quarts regular to 1quarts LL100, I have been running this with my husqvarna equip with no carburator problems. It keeps from having to re-build the carburators every year.
This tech, said he has run straight LL100 and found that the engines run hotter and have lead build-up on the spark plug tips.
