BID ON A FORUM AUCTION!
My first guess is that it was left with gas in it.Carb clean or more likely, rebuild time. Get out the Varsol!
piedmontWhen you say it won't come close to "cranking", that to me means it will not turn over when you pull the starter cord. Or do you mean it won't come close to "firing" or "turning over under it's own power" ??Old cars and tractors that had a crank, one could crank all day and not get the engine to fire and run. Is the engine siezed tight, so it won't crank?
Dont laugh, but is the saw ON/OFF switch in the ON position. Been there done that.Is it a Walbro or the Zama carb? I have a extra good working order Zama laying around, I replaced it with a before epa Walbro and sold the saw.Carb rebuilds take about 30mins to a hour to due, carb kits are $3 Dia kit -$10 complete kit for the carbs for that saw.
Compression tester can be had for $20. Pull till the psi reading stops.Piston shows no signs of scoring? How about a stuck ring in the groove? Coil come loose? Check with index card between contacts and tighten down or a business card or a piece of paper folded to make 3 layers. Place between contacts, Loosen coil, index card etc between contacts, then tighten back for correct gap. Check for spark. Spark testers I use cost $3, go to plug and then to wire with a little light inside, pull over and can see light flickering.
When you took the piston out of the cylinder did the ring expand or was it stuck in the piston groove? Did you have to compress the ring to reinstall the piston in the cylinder?
