Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Building with green wood  (Read 4890 times)
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
Re: Building with green wood
« Reply #20 on: January 19, 2008, 01:05:17 pm »
Is there a good source of information on building with green wood?
Yes- Don't
Anyway, I'm looking for information.
*see above
Nate
[/quote]
Wood bends best when its wet and hot.
Green wood bends easy, also not restricting it during drying allows it to warp easier.
Buiding with green wood (except for projects that exploit the assests of green wood) is like trying to re-invent the wheel.
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
Offline Nate Surveyor
  • If you like work, you will always be happy!
« Reply #21 on: January 20, 2008, 01:32:39 pm »
I live on a hilltop. The wind never stops for long. If I mill wood, and sticker stack it, it looses 1/2 it's weight in about 3 wks. (just guessing) So, I guess I am not really using GREEN wood, but NOT all the way dry, like a kiln does.
Is there a device to measure moisture in this wood?
So far, it all seems stabilized. Slight shrinkage is all.
I am building a kids cabin for a test run.
Nate
I know less than I used to.
Offline Ianab
« Reply #22 on: January 20, 2008, 03:19:37 pm »
Quote
Thats a moisture meter  ;)
If you dont have one you can actually use weight of the wood to measure the moisture content. To get a rough quide as to how dry it is, take a sample board and weigh it. Put it back in the stack, wait a week and weigh it again. It should be lighter because it's lost water. Do this each week, and when it stops loosing weight, its 'dry'. This doesn't tell you EXACTLY how dry, but it's as dry as it's going to get in that location.
If you want to know the exact moisture content you can also use a small sample board, an oven and some accurate scales. You weigh the board, then bake or microwave it on low power untill it's bone dry. Weigh again and see how much water your sample lost. That lets you work out what the M/C of your sample was.
It's also an interesting experiment to weight the 0% moisture sample again over a few weeks and watch how it gains moisture again from the atmosphere and ends up at a similar moisture content to the original air dried wood.
Cheers
Weekend warrior, Peterson 8" WPF with Stihl 090 powerhead, Dolmar 7900 and Stihl MS310 saws and  the usual collection of power tools :)
Offline stonebroke
« Reply #23 on: January 20, 2008, 05:13:58 pm »
baileys sells moisture meters.
Stonebroke
Offline andybuildz
  • "If opportunity doesn't knock, build a door"
    • WWW.CLIFFORDRENOVATIONS.COM
« Reply #24 on: January 21, 2008, 12:35:34 pm »
I have this one http://www.amazon.com/Sonin-50211-Rapitest-Concrete-Moisture/dp/B0000224DA/ref=sr_1_3?ie=UTF8&s=hi&qid=1200936690&sr=1-3
It's cheap but it works great for me. I originally bought it from my paint store. I wanted to check the moisture content of the cedar shingle siding I put up so I'd know when it was safe to prime and paint it.
It really is a good little meter especially for the price.
Most paint stores sell them or you can get it from amazon cheap enough.
http://HTTP://WWW.CLIFFORDRENOVATIONS.COM
"How people treat you is their karma, how you respond is yours"
Offline scsmith42
« Reply #25 on: January 21, 2008, 01:38:10 pm »
Nate, Delmhorst manufacturers meters primarily for measuring wood MC%.  You can buy one through Nyle Corp (FF Sponsor).
Bailey's also sells meters.
If you're only measuring 4/4 wood, then a pin-type meter with 1/2" pins (or 3/8") will work fine.  If you need to measure 8/4 or larger, you will either need a meter with a slide hammer and 1" pins, or a pinless meter that will measure at least 1" deep.
I have a Merlin HM8-WS25 pinless meter designed for kiln operators (made in Austria - supposed to be very accurate, and measures up to 1-1/2" deep), and also some Delmhorst units.  They both work well, but the pinless meter is much quicker when I have access to the surface of the boards.  The slide-hammer works better when measuring inside the kiln.
Scott
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #26 on: January 21, 2008, 06:34:35 pm »
Built fresh off the saw, from framing to siding. Siding was logs one day and nailed up the next.  It still looks as good today as it did when we finished it.  :)
Here is the story of building it...
http://www.forestryforum.com/board/index.php/topic,14094.0.html
Offline logwalker
  • Got Logs??
« Reply #27 on: February 01, 2008, 11:46:57 pm »
Dry wood is great but not mandatory. If you are using large timbers you need to know it takes years for them to dry. I have built or helped to build several homes & large shops and never once used kiln dried wood except for the glued-gusset trusses to cover the back half of the above structure, our current home. Framing with green wood is actually preferable for the ease of nailing and lack of splitting when nailed. By the time the roof is up and the frame is sheathed the the framing will be at or below 18% in most cases. Remember you have to build smart. I have seen builders use a temporary brace to support a heavily loaded beam as it dried but it probably wasn't necessary. Joe
Hey, I forgot how cute that place was.  8) 8)
Offline HOOF-ER
« Reply #28 on: February 07, 2008, 12:54:38 am »
Built a large horse barn  this summer. Used 10" white pine BB
Owner was in hurry so put up boards soaking wet. I watched and put the cup toward the building and angle nailed it. The west side got the most sun and cupped the worst.
Renailed some of the worst. Looks great though. I would use heavier battens next time .   Just got the picture thing down tonight thought I would repost this with the pics Here is the stalls too. The stall doors have pecan around them  with wormy red oak for the center walk area
Home built swing mill, 27hp Kawasaki
Offline Norm
  • What's for supper!
« Reply #29 on: February 07, 2008, 03:12:28 pm »
Very nice!
WM LT30HDD-E25
Offline Don P
    • Calculator Index
« Reply #30 on: February 07, 2008, 06:05:43 pm »
I'll second that  8)
Got any pics of the roof framing?
Offline solidwoods
« Reply #31 on: February 07, 2008, 06:33:01 pm »
Why make things hard on yourself?
Just air dry the wood for a few months,, BOOM no bad lessons learned.
jim
Ret. US Army
N. Central TN.
Offline HOOF-ER
« Reply #32 on: February 07, 2008, 09:31:18 pm »
DonP , No pics of the framing. I made my own trusses with two rows of 4x4 to help support. Owner did not care about the post in the loft , so I like to over build. The 4x4 's are over the lower 4x6's.
Offline StorminN
« Reply #33 on: March 19, 2008, 03:16:34 am »
Hey guys,
An update here... I got a Lignomat MC meter and tested some stuff... the western red cedar siding I milled last week varies from ~40-60% MC, depending on where in the log it came from... however, the WRC siding I milled and stickered just after Christmas* is now about 20% MC... and the rest of the frame of the cabin (fir and hemlock), is about 18% MC... this includes some of the kiln-dried stuff that has been under cover, but not closed in... so I think I'm going to start siding pretty soon...
-Norm.
Happiness... is a sharp saw.
Offline SwampDonkey
  • Large Tooth
« Reply #34 on: March 19, 2008, 05:56:36 am »
Most all the barns and sheds, with exception of a potato storage shed, we built on the farm in my lifetime was from green ungraded lumber cut from the farm.  8)
Dirty Harry
Offline Dale Hatfield
  • A plan is a start to a great ending
« Reply #35 on: March 19, 2008, 08:34:14 pm »
Hey guys,
-Norm.
Norm Can ya run a few tests for us? Take the high tech toy to town and grab a few tests from the 2x4,s or whatever  lumber size that you have to compare at the lumber yard one indoors and one out. Lets see how the numbers work out.
Dale
Chainsaw Carver
Saw Anywhere!
