Get your Forestry Forum Hats while they last!
Make sure their is a line shut off close to your hookup..... it will keep oozing after you disconnect. Trash pump should work ok, I've pumped oil with a swimming pool pump, as long as it was warm enough, 70 degrees or so.To StorminN: I burned straight veggie oil in my tractors for the first year. Actually, I cut it with 10% kero, 5% gasoline, and about 1 pint of naptha in 20 gallons of mix. It ran the engines fine, but I'd plug filters after every 100 gallons. Slime on the filters.After 100 hours of run time, one of my 90 hp tractors bent a pushrod, and I got scared and set up to do the whole conversion. When we took the engine apart, it was pretty gooey in there, and the guy helping me said that the veg. oil stickiness was maybe causing the rods to "hang up".I know that my engines oozed a bit, at the fuel pump and on the block, and that went away when I did the tranesterification. What I learned from the experience is that in the short term, for an engine you don't care about, just run regular oil, and maybe cut it with some gasoline to bring the viscosity down and help with the ignition point of the fuel. In the long term, for engines you care about, don't do it.
