Get your Forestry Forum Hats while they last!
Hey Bob, good to see you again. Where you been hiding? Here's a link you got to see, it makes hydraulics a snap. http://64.78.42.182/free-ed/MechTech/hydraulics01/default.asp
Bob, Those 1/2 inch threaded rod with only 10 threads per inch will require a lot of cranking. Are you going to get a hydrualic motor?
Bob, one axle enough for that weight & length? Just wondering.......
The only other thing on my mind is that 1/2" acme Bob - It just seems light for the massive head weight you're going to have.
I saw an old electric "scooter" type wheel chair for sale the other day for pretty cheap, and all I could think about is to use those electric motors for travel on a sawmill. I dont see why they wouldnt work for the lift on a headrig too.
If you still want to saw a larger log but not a swing head . Make the main head frame adjustable . Then all you would have to do is slide it out to full extention to saw and retract it for transport. Use a hydraulic cylinder for the job and put in a large pin at full extention and then at retract for travel.
Quote from: Don_Papenburg on November 20, 2007, 09:22:25 pmIf you still want to saw a larger log but not a swing head . Make the main head frame adjustable . Then all you would have to do is slide it out to full extention to saw and retract it for transport. Use a hydraulic cylinder for the job and put in a large pin at full extention and then at retract for travel. Good idea, still need to beable to adjust the band tension.Anyone got any ideas about useing a hudraulic cylinder to mantain band tension and to retract the bandwheels to change blades?
One of the features that my E Z Boardwalk has is a garage door spring to help lift the head. It is raised and lowered with a hand operated winch very easily.Maybe you could incorporate a spring on yours Robert, to assist the acme rod.
..............Now all I gotta do is find someone throwing out a decent set of band wheels....
