I understand that alder is used in furniture, being a cheaper wood than maple. Alder lying on the ground with its bark intact rots quickly, however, if debarked it resists rot and decay. I have been hewing beams out of alder without too much effort by cross-cutting with a powersaw at one foot intervals and adzing off the wood in chunks. I tried this procedure with fir; that was a different story. It was hard work and the results were disapointing -- I switched to using an alaskan mill with pleasing results.
Comparing the alder with fir as material for beams, I have discovered that some of the fir had decayed while the alder during the same period did not turn into mush. Rather, the alder beams tended to split at the ends.
Does anybody have experience using alder and fir for beams?
