The Forestry Forum CRASH OF 2007 ARCHIVES
General Forestry => Forestry and Logging => Topic started by: Dave Shepard on October 15, 2007, 18:15:16
Title: Timberjack 208D grapple skidder questions.
Post by: Dave Shepard on October 15, 2007, 18:15:16
It would appear that I have been roped into a TJ 208D project. How did I get roped in, you ask? Well, I'm self-roping, of course!
It needs a few things, but appears to be in decent shape. The rear hubs have been taken off to get rebuilt, still waiting to find out if they are going to reappear.
#1 This machine does not have a winch on it, but does have a hyd. valve marked "winch". There is a driveshaft yoke on the transfer case that appears to go to a hyd. pump. Would this machine have had a hyd. winch?
#2 Would this machine have had a torque converter, or is it a straight manual transmission with just a clutch?
#3 As this is not a powershift machine, does it use some sort of a reverser, or "Johnson" bar as some have called it?
If anyone has any input on this machine, I would appreciate it. I have done a bunch of hunting around on the internet, but have not been able to find any info other than machines for sale. I will probably be looking for service/repair manuals as well. Thanks.
Dave
Title: Re: Timberjack 208D grapple skidder questions.
Post by: Dave Shepard on October 16, 2007, 00:45:50
#4 This machine has chains only on the front. Is there a reason for this? I have seen many skidders that are only chained up on front. Thanks.
Dave
Post by: amberwood on October 16, 2007, 03:03:10
Dave.
All manuals etc are avail from the John Deere site..I managed a copy for my 67' 205HR. PDF download in a few minutes.
www.jdtechinfo.comDTR
Post by: a old timberjack on October 16, 2007, 04:22:16
i ran a 208 for 2 seasons for a guy , nice machine it sounds like it has a manual transmission. if you are not sure just look on the floor , 2 pedals or 1 beside the throttle . i own a 225 c model, it is a early 70,s machine.
Post by: thecfarm on October 16, 2007, 06:25:45
I would want something with a winch too.How much will one cost to add on to this one?It would be a shame to cut down a 4 inch red oak to get to a 2 foot pine.That's about all I know.
Post by: Dave Shepard on October 16, 2007, 09:23:27
Thanks everyone. It has two pedals on the floor. They both move together, but I am guessing they are just riding on the same shaft and need some lube. I definately want to rig up a winch, I might have to use the Farmi to get the logs to the skid road, and then use the TJ to get them out of the woods. A bit of a pain, but I want to do as little damage as possible. I'll get some pics when I get it home.
Dave
Post by: Dave Shepard on October 16, 2007, 21:23:41
I tried to locate Timberjack info at that site, but couldn't get to cooperate, what steps did you take Amberwood? Thanks.
Dave
Post by: sawyer40 on October 17, 2007, 00:38:33
Wow a 208 grapple skidder I didn't think they put grapples on anything smaller than a 240. My 230 is direct drive from the trans it had some kind of reverser but that was long gone before I got it. So I have to shift between forward and reverse manualy using the cluch. Also I have a drive shaft off a pto on the side of the transfer case that powers the winch and a hydraulic control that works the winch and locks the brake on. As far as I know the only hydraulic pump on that machine is up front off the crankshaft. Does your 208 have a 353 detroit?
Post by: Dave Shepard on October 17, 2007, 00:49:42
Yes, it is a 3-53. I spent a few minutes this afternoon poking around on it. It has a four speed transmission, which is a New Process. There is a lever that goes either into the front of the transmission, or ahead of it, don't know what that is for. Also there is a lever that goes back to the transfer case, I think that might be the reverser. There is a short driveline going to a pump at the very back of the machine, but it is not plumbed to anything.
The entire winch works has been torched out, so I have no idea what was there. I am going to see if I can find one in a junk yard and cut it off and weld it onto this machine, the grapple will be nice, I am sure, but I would really have liked to have had a winch. If I can't find anything in a junkyard, I will have to rig something back there. I'm looking forward to getting it home so I can start tinkering, but we still have to find the rest of the rearend. Not only are the planetaries missing, but the pumpkin is gone too. This is not my responsibility, however, as the machine is to be in operating condition, per our agreement. Apparently the parts were removed to be rebuilt, still hunting them down. I am amazed at the condition of the machine, all of the tinwork is straight, and it isn't a huge mess of weld repairs, although there are a couple of small things that need fixin'.
Dave
Post by: sawyer40 on October 17, 2007, 06:52:08
The lever going to the transfer case on mine is a hi and low gear. With that each gear in the trans will have a high and low
Post by: sawyer40 on October 17, 2007, 06:58:10
From what I've seen the 208 -225-230 tj are all pretty much the same with slight differances. I've seen one 208 and it looked exactly the same as my 230 except mine has 34"rubber I couldn't see any other differances on that machine.
Post by: amberwood on October 17, 2007, 08:46:16
Dave..
JD Manualsjust need to register as a user, then change the option to download, add a visa card etc and you have manuals. Mine are a scanned copy of an original printed TJ manual, complete with a couple of annotations from a previous owner!
DTR
Post by: Dave Shepard on October 17, 2007, 17:11:09
Thanks amberwood. I guess that means that the machine is at least a 79 or older. I wonder if a regular JD dealer (not forestry) can order from the bookstore, the friend I am getting the skidder from owns five dealerships.
Dave
