Get your Forestry Forum Hats while they last!
MS 361 MS 361 C-B (quick chain adjuster) is this just a bell/whistle?MS 361 (with a secondary chain braking system. This saw also features the ElastoStart™ shock-absorbing starter handle.) more bells?357 XPPS 5100S - redheaded stepchild or better for my needs?leaning towards an 18 inch bar...
Maybe 16 iinch is a good compromise...I will also be cutting a fair amount of small and medium limbs on the ground.
I`ll throw in my two cents for the 361 or the 357xp, the 359 or Jonsered 2159 are a distant second compared to the first two saws when they are all unmodified.If however only a few of your trees are 18" or larger and the majority of stuff is much smaller, say 14" or under, I`d look at a Husky 353 or Dolmar 5100s.
My opinion on bar length is ta go with da one da saw is normally sold with. ya'll find dat da saw will be balanced better with dat length. My CS670 is perfectly balanced with da original 24", but noticably nose-heavy with da 32". A balanced saw is much less fatigueing ta use.
