Get your Forestry Forum Hats while they last!
jokers, is the smaller saw better because of weight or maneuverability? I was thinking that you would want a bar that could pass through the larger trunks in a straight cut. If it makes a difference I'm thinking about cutting a lot of firewood.
Maybe 16 iinch is a good compromise...I will also be cutting a fair amount of small and medium limbs on the ground.
jokers, which did you mean when you said "the lighter saw"?
What would I give up by getting a ligher saw like a MS 260 Pro or a 353, or a ps5100?
Is anyone going to back up good 'ol DanG about Echo?
Quote from: GW on August 13, 2007, 04:22:36 pmIs anyone going to back up good 'ol DanG about Echo?No
