Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: bar problems  (Read 849 times)
Offline sawyerkirk
  • Give me a lever big enough and I'll move the world
bar problems
« on: April 07, 2003, 11:36:25 am »
what causes a saw to curve as it goes down through a log? I thought it was curved by a burr on the bar edge, but I cleaned the edge of the bar an it still happens. I get about 4" down into the log and it takes a drastic right turn. Any thoughts?
Offline cut2size
  • Logs to lumber, lumber to furniture
Re: bar problems
« Reply #1 on: April 07, 2003, 12:19:39 pm »
Sometimes the teeth of the chain are duller or shorter in length on one side, this will cause a curve cut.  Also one side of the bar is worn more than the other and this will cause a cut to curve.  The best way to tell if it is the bar is to stand the bar on a flat surface and check it for perpindicular with a good machinest square (checking both sides).  I have jointed a bar on a grinder much the same way as wood on a jointer.
HTH,
David
cut2size
Offline Kevin
    • The Milling Masters
Re: bar problems
« Reply #2 on: April 07, 2003, 03:12:48 pm »
If you dress the bar, get all the cutters the same length then put the same chain back on it will likely wear the bar again.
The chain is probably worn on the bottom of the links.
Offline Captain
Re: bar problems
« Reply #3 on: April 07, 2003, 08:19:26 pm »
I agree with Kevin - chances are your drive links are worn -OR-your bar groove is too wide.
Evening the bar edges is important, but equally important is checking the width of the groove.  The best way is with a couple of new chain drive links in absence of the correct size feeler guage.  I bought a "bar rail closer" years back from my cousin in the business.  It works great for a small width adjustment.  I have seen the same types at Bailey's and Madsen's.
I also cut circles (or try) if I forget to sharpen both sides of the chain  ::).
Captain
Offline sawyerkirk
Re: bar problems
« Reply #4 on: April 09, 2003, 04:37:42 am »
well, I spent about an hour working n the chain, getting every tooth just right and it helped considerably, but still turns a bit. I'm about due for a new chain, and will have my dealer check out the bar and replace if needed.  THANKS
Offline Kevin
Re: bar problems
« Reply #5 on: April 09, 2003, 05:06:52 am »
It's a good idea to turn the bar over on a regular basis so the wear is even top and bottom.
Saw Anywhere!
