Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Modifying 372 XP  (Read 1714 times)
Offline TJACK
  • Forester Wanna-be
Modifying 372 XP
« on: March 15, 2003, 07:40:25 pm »
I just removed the muffler from my 372 XP and after a thorough review am looking for some advice.  Should I cut the three spot welds that attach the deflector to the main can, so I can get to the port under the spark arrester or is there a better way (spark arrester is removed with a screw)? My goal is to match the exhaust size to the intake size on the muffler.   I have a mig welder, so re-attaching the deflector will not be an issue.
I looked at the exhaust port on the cylinder and it is to my suprise, very smooth just coated with a black oily film.  Is there anything I should do to the exhaust port on the cylinder to improve the quicknesses of this saw or is the improvement to the exhaust enough.
Thanks,
TJACK
Offline Oregon_Rob
  • NW Oregon
    • Not open yet, but soon I hope
Re: Modifying 372 XP
« Reply #1 on: March 16, 2003, 01:19:45 pm »
TJACK,
After some advice, I cut a 7/16-1 1/8" slot through the front maunting bracket and muffler. That way you can really open it up and still put in the spark arrestor screen.
Rob 8)
Chainsaw Nerd
Offline Oregon_Rob
  • NW Oregon
« Reply #2 on: March 16, 2003, 01:29:26 pm »
Try this link and check out the photo kd385mufflerhttp://www.arboristsite.com/showthread.php?s=&threadid=5127&highlight=372+muffler
Chainsaw Nerd
Offline Oregon_Rob
  • NW Oregon
Chainsaw Nerd
Offline TJACK
  • Forester Wanna-be
« Reply #4 on: March 16, 2003, 04:24:50 pm »
Rob,
Thanks for the information.  I guess there is more than one way to accomplish the goal.  I was intending on removing the deflector and opening the port below to about the same size as the inlet.  The way you have explained by cutting the oval hole in the front looks easier, just have to get a screen.  Have you ever modified a muffler as I described?  If so, how well does it work?  What type of gains should I see with your design.
Thanks for your help.  If it works, I have a 359 next in line.
TJACK
Offline TJACK
  • Forester Wanna-be
« Reply #5 on: March 16, 2003, 04:32:04 pm »
Rob,
I just looked at the photos again in the link.  Where can I get a larger deflector.
Thanks,
TJACK
Offline Oregon_Rob
  • NW Oregon
« Reply #6 on: March 17, 2003, 07:03:13 am »
Power gains: there was a noticeable gain in power; I don’t know how to quantify it. One option I didn’t mention is to buy an already modified muffler from Walkers saw shop in BC, Canada. I think you would ultimately get even more power and I don’t think they are all that expensive; the exchange rate helps a lot.
When you open up your muffler, be sure and check your carburetor adjustment. I don’t know anything about your mechanic skills, so I will throw this in. Opening up the carb, can cause the saw to run a little on the lean side. Don’t run any two cycle lean or you are heading for hard times.
If you are interested in parts, I suggest you contact Dennis Gaffard, he posts here as Dennis sometimes. He customizes saws to really get power and life out of saws and also builds racing saws.
Link to Walkers: http://www.walkerssawshop.com/index2.html
Chainsaw Nerd
Offline Oregon_Rob
  • NW Oregon
« Reply #7 on: March 17, 2003, 07:38:11 am »
http://www.madsens1.com/sawtune.htm
Good link regarding setting the carb.
Chainsaw Nerd
Offline Hotsaw
« Reply #8 on: March 17, 2003, 04:23:56 pm »
Hello all, If you really want a 372 that run's extremely well (or any saw of your choice) May I  suggest you contact
Ken Dunn  Ken is the master ,,costly and worth every penny
Or Dan Henry  Dan is a close second to Ken and has a fast turn around time and your best bang for you buck.
EDITED BY ADMIN (GIVING PERSONAL CONTACT INFO FOR ANOTHER PERSON IS FORBIDDEN)
http://www.forestryforum.com/disclaimer.htm
Offline TJACK
  • Forester Wanna-be
« Reply #9 on: March 17, 2003, 06:53:14 pm »
Thanks for the advice.  I am mechanically inclined ( used to run and tune motorcross bikes and work on a DIRT Modified).  Therefore, I understand the link for adjusting the carburator, just need a good tach.  How much if any am I reducing the saw life.  Currently, I run all my saws at 40-1 using 93.5 Octane.
Thanks again,
TJACK
Offline Oregon_Rob
  • NW Oregon
« Reply #10 on: March 19, 2003, 11:36:12 pm »
The info I have seen indicates that it should extend the life of a saw, mostly by making it run cooler.
Chainsaw Nerd
Saw Anywhere!
