Recent
355 Guests, 2 Users
Ljohnsaw, Brad_bb
Welcome to The 2024 Forestry Forum!
Do you have trees to grow? Logs to saw? A forest to manage? Chainsaws to fix? A sawmill to purchase or maintain? Timber related business to run? Lumber to dry? Trees or plants to identify? A cabin to build? Are you hungry and like FOOD?
Or would you just like to pull up a stump and visit with a friend?
If any of these and a multitude of other topics apply, then The Forestry Forum is the place for you.
What Will you Find on the Forestry Forum?
Pages: [1] 2 ... 40
Ez Boardwalk model 40 runs 11/4" blades. I tried 11/2" and was very pleased with the results. I'm considering using only 11/2" blades in the future. My question is do I need to change roller guides to 11/2"? If I continue to run the smaller guides am I causing damage that will show up in the future?...
Read More
3 Comments
I'm trying out some shelving brackets I made to store lumber in a shipping container. The brackets hang on the loops along the top of container sides. You can buy these type brackets but they're quite expensive at around $4-500 for each bracket.
They're a fair amount of work to build but they seem to work ok. In the last pic I've got them loaded up pretty good and it seems to handle it ok. The lumber that's on the shelf and under it was enough to pretty well cover the floor of the container and was kind of hard to get around on without knocking stacks over.Read More
0 Comments
I just spent the last hour (that's all I'll admit to - I spent more than that) futzing around getting my LT35 levelled. And yes, I'm still learning. I find the stock outrigger "jacks" to be just a little bit better than worthless. End do end, it's not hard to get the stock outriggers set, moving the head up and down. But I had to lift the rail-side wheel about 3" off the ground to get the bed close to level using a hydraulic jack.Read More
10 Comments
I usually saw by myself and enjoy it that way. Its my time to work at my pace and think things through. Today being the weekend and cutting more cedar for my Daughter and SIL I had him and my youngest Daughter which the wood is for her older Sister helping. It was a pleasure to have them help. I can...
Read More
13 Comments
Good evening all,
I have a 2022 LT40 with the 38hp Kohler. This morning I started it to warm up before sawing. Within a few minutes of it idling, I heard the idle drop slightly, and began running a little rough. Upon engaging the blade the engine was slow to speed up, and lacked power. It appeared to be running on 1 cyl intermittently. Read More
4 Comments
Pages: [1] 2 ... 40
