Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Can I use Eastern Hornbeam (iron wood) for fence post?  (Read 1866 times)
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
« on: April 22, 2007, 10:17:07 am »
My extension agent told me it would be a good idea to remove as much as I can in the area's where my hard wood is trying to recover from an agressive cut 15 years ago...
So I have litterally tons of this stuff with shaggy bark, about 20-30 ft tall, 6-8 inches in diameter, Straight as an arrow, and really dense. Can I use it for fence post?? If it rots, is there any way to treat it to make it acceptable as a fence post alternative?
I also have a 10 acre stand of red pine....would that be a better option? Most of it is 10-18inches in diameter so I would have to slice it up...I want to remove that stand to expose a bunch of cherry we have below the pines.
I have to fence nearly 80 acres so if I could use materials of my farm it would help the cost of this project..
thanks in advance for the advice or direction on where to get the advice.
Husqvarna 365/372 Blend, 365SP, 268 WJL, 266se/272 blend, 272XP, 272XP MotoM, 61/272XP WJL Blend, 351 MotoM, 455, 238 WJL, 440e, Homelite Two  S-XL 925's, XP-1020A, Jonsered 2094, Three 920's, CS-2172, 2040/Craftsman46cc Blend, 2051, 49sp, 621
Offline DanG
Re: Can I use Eastern Hornbeam (iron wood) for fence post?
« Reply #1 on: April 22, 2007, 10:33:23 am »
From what I understand, Hornbeam isn't rot resistant enough to use for posts, and is too dense to take treatment well.
The red pine is probably a better bet, if you can get it pressure treated.  Down here, it costs about a buck and a half to get a 8' 4x4 treated.  Fencing in 80 acres is and expensive and laborious proposition.  Using wood from your own land would certainly ease the pain a lot, especially if the trees have to come down anyway. :)
Offline Phorester
  • Can't have a healthy forest without cutting trees.
    • About Forestry Forum Host
« Reply #2 on: April 22, 2007, 11:06:20 am »
If you had a naturally rot-resistant species, like locust, processing your own posts would be worth it.  But as Dang says hornbeam is too dense to take preservatives and will rot without them.  Pine will rot without preservatives.  But I know of no preservative available that an individual can apply himself.  (Maybe there is one I'm not familiar with) Creosote, which could simply be painted on the outside of wood, can no longer be used.
Do some figuring on costs in your area to buy treated posts versus your time, labor, and expense of doing it yourself, if you can find a preservative you can apply.  I think you will find it more economnical to have a timber sale of the red pine and buy treated fence posts with that income rather than cutting and otherwise processing your own posts. Hornbeam makes good firewood, your size trees might not have to be split, and maybe you could generate income from that.
About.Forestry.Com forum host. Ya'll come: http://forestry.about.com/mpboards.htm
Offline thurlow
« Reply #3 on: April 22, 2007, 12:16:57 pm »
You didn't ask, but unless your time is unlimited (to complete the project), I think you'd be much better off to buy metal "T" posts, except for the corner/brace posts.  I've put untold thousands of black locust and ERC in the ground and when labor was a lot cheaper, it was cost effective to use them.  I've still got a Shaver post driver and a hydraulic drive 3-point hitch digger, but it's been years since they were used.  You can drive a BUNCH of metal posts while you're cutting/splitting/digging a hole/tamping one wood post.
Here's to us and those like us; DanG few of us left!
Offline WDH
  • April 1998 - August 2008
« Reply #4 on: April 22, 2007, 11:53:44 pm »
What you are referring too, I believe, is not hornbeam (Carpinus caroliniana) , but rather hophornbeam (Ostrya virginiana).  The hornbeam is called ironwood as a common name, but the bark is smooth, dark gray, and ridged (fluted) like the wood is showing off its muscles.  Another common name I have heard is muscle wood.
On the other hand, hophornbeam (which is what you have from your description) is sometimes called ironwood because it is so hard and it is also called blue beech.  It has a brown scaly bark, easily rubbed off by hand.  The leaves of the two species are similar, but the bark is not.  While hard, neither hornbeam or hophornbeam is notably rot resistant.
It sounds like you have the hophornbeam from you description of the bark.   I have it on my place and it is a terrible understory pest.  Seeds prolifically in the understory, especially after fire.  It is not going to last a suitable time in the the ground as a post.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline bitternut
« Reply #5 on: April 23, 2007, 12:52:06 pm »
He definitely has Eastern Hophornbeam. I am located not too far west of his location and I have lots of it in my woods also. We have both types of " ironwood " actually. We have a lesser amount of the smooth blueish barked variety which usually is referred to as muscle wood by a lot of people. It is also not rot resistant. Both types make great firewood but lousy fence posts.
Offline Phorester
« Reply #6 on: April 23, 2007, 08:26:31 pm »
These names are easily mis-applied since they are so similiar.  The point though is that no matter which one, neither is good for fence posts.  You'd think something that hard would last forever.  I've had both species create sparks when cutting with a chainsaw.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #7 on: April 25, 2007, 06:45:39 pm »
I have hophornbeam on the farm, I couldn't imagine what you'd use it for. It gets up to 3-4" and dies. The bark holds the tree up for a while, but the wood on the inside is just powder.
Dave
Wood-Mizer LT40HDD51 Wireless, Kubota L48, Honda Rincon 650, TJ208 G-S, and a 60"LogRite!
Offline Dodgy Loner
  • It's an anagram for "dendrology" and in no way a reflection of my personality
« Reply #8 on: April 26, 2007, 01:51:59 pm »
Hi Dave, you'll find that the size hophornbeam (or any other tree) can reach is heavily dependent on the site.  I've seen many hophornbeams on moist slopes near river bottoms more than 60 feet tall and 14" in diameter, and they've been know to get much larger.  I once sawed one 12" in DBH for lumber, and it was about like cutting up a boulder.  The wood itself is attractive, resembling maple or birch, but they are usually too small and tough to deal with.
The sooner you fall behind, the more time you'll have to catch up.
Wood-Mizer LT-15, 25 HP
Offline WDH
« Reply #9 on: April 26, 2007, 10:47:24 pm »
How would it be for bowl turning?  Anyone turned any hophornbeam bowls?
Offline Dodgy Loner
« Reply #10 on: April 27, 2007, 10:18:36 am »
I've never tried it, but I suspect it would.  Dense hardwoods polish up a lot better than the softer ones.
Offline WDH
« Reply #11 on: April 27, 2007, 10:25:36 am »
If you want to try it, I have some that are probably large enough for bowl stock.
Offline Dodgy Loner
« Reply #12 on: April 27, 2007, 03:14:37 pm »
I'd love to give it a spin.  I'll turn anything once :)
Offline SPIKER
« Reply #13 on: April 27, 2007, 07:18:35 pm »
This is a great topic;  I have the same type as described hophornbeam on my place and was thought growing up the smooth bark hornbeam was IRON WOOD and then the have the locals told me that the hophornbeam was iron wood I got confused quite well...  I know have to edit a few pictures on my site here to note that the ironwood is actually hophornbeam.
I have a lot of it too some of which is 12~18" DBH and 60' high...   Many of these are hollow inside though...   I was thinking same as above that they would make GREAT BEAMS if they could be treated for ground contact somehow...   (the ones that weren't hollow that was.!)  These DO make GREAT flowerpots. I take some of the hollowed out ones BURN the inside and Drill 1~1.5" holes all around it and plant Hens & Chicken plants in them (straw berries grew well in there too!)
thanks guys
Mark M
http://www.forestryforum.com/gallery/albums/userpics/12855/hophornbeam.jpg
Offline WDH
« Reply #14 on: April 27, 2007, 07:24:45 pm »
If you ever thin out your woods, it will take over as an understory plant.  It has no real wildlife value, is marginal in size for lumber, and unfortunately, can be tough to control.
Offline SPIKER
« Reply #15 on: April 27, 2007, 08:07:44 pm »
trying to put pic in post like on the general gallery
mark
Offline WDH
« Reply #16 on: April 27, 2007, 09:13:15 pm »
Mark, you hit the mark with that pic.  That is the shaggy villian itself..............
Offline treebucker
  • God 1st.
« Reply #17 on: May 02, 2007, 07:10:21 pm »
My uncle told me that he cut many ironwood fence posts when he visited a farmer in Oklahoma. He said that was all the local farmers were using. Because of this story I made the mistake of cutting a few hornbeam fence post. They were solid and defect free.  I left them on the ground over the winter. When I came back they were covered in mushrooms. I've never seen wood that rotted so quickly. All of this was due to confusion over which one was truely ironwood. This was several years ago. So I decided to do some research.
I found out there are over 50 species world-wide that are called ironwood. The concenses is that hophornbeam is ironwood but that hornbeam is often mistakenly called ironwood. The pioneers used hophornbeam extensively. It was the preferred wood for wagon axles and wheel hubs. It was also used for tool handles.
I've seen plenty of hornbeam (blue beech, muscle wood) around here. But I can't seem to find any hophornbeam. I suppose it's rare in this neighborhood. I can still hear the story my dad repeated to me several times that he, his brothers, and my granddad (who was a logger) cut down an ironwood tree that measured 4' at the butt. My dad was rather proud of it. I have never questioned my uncle to find out what he considered ironwood.
Last night I lay in bed looking up at the stars in the sky and
I thought to myself, "Where the heck is the ceiling?!" - Anon
Offline WDH
« Reply #18 on: May 02, 2007, 09:35:46 pm »
Treebucker,
Very informative post.  It seems like any wood that is hard is called "ironwood" by the locals.
Offline treebucker
  • God 1st.
« Reply #19 on: May 03, 2007, 08:51:56 am »
Here is a very informative article on hophornbeam.
I can only guess that hophornbeam fell out of favor because of the mechanization of woodworking. All who have tried to machine it have had trouble. Why else would a once prized wood now be considered a trash tree? I did not find any historical references to complaints about its working properties. This leads me to believe it wasn't especially hard to work with hand tools.  But this is an assumption.
I'm glad there are people here who have experience with its tendancy to rot quickly, otherwise the first time I had the opportunity I would have cut some for fence posts.   :)
Saw Anywhere!
