Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Marking a property line.  (Read 6478 times)
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
Re: Marking a property line.
« Reply #80 on: April 13, 2007, 01:24:47 pm »
I've been playing with Map quest a bit, and using their scale and photoshop came up with this photo. I have more powerline then I though if my geometry is close.
Offline Stephen Alford
« Reply #81 on: April 13, 2007, 04:08:31 pm »
Thats got to be the prettiest hishers I have ever seen.  :)
logon
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #82 on: April 13, 2007, 04:56:54 pm »
  Is that the creek to the left of the red star that you where talking about  ???
   Marcel
Offline SwampDonkey
  • Large Tooth
« Reply #83 on: April 13, 2007, 06:14:18 pm »
Well I found ya on Streets and Maps anyhow.  ;)
Dirty Harry
Offline Jeff
« Reply #84 on: April 13, 2007, 06:20:56 pm »
Thats Lou's driveway.' Its about 50 or 60 feet wide from tree to tree line
What the heck is a hishers?
« Reply #85 on: April 13, 2007, 08:34:26 pm »
With all the discussion on what would be appropiate signage I was thinkin  of posting HIS on the North Caribou and HERS on the South Piesley . :)
logon
Offline Jeff
« Reply #86 on: April 13, 2007, 08:39:27 pm »
That'll work!  ;D
Offline isawlogs
« Reply #87 on: April 13, 2007, 09:03:31 pm »
There always a good explanation on here ... Good thing, cause I'd be so lost at times  :o :D
   Marcel
Offline Furby
  • Blurb....
« Reply #88 on: April 14, 2007, 01:45:32 am »
Gotta ask...........
The pin in the NE corner, is it an actual corner pin, or is it a marking for the road right away?
Offline Jeff
« Reply #89 on: April 14, 2007, 10:45:53 am »
That was a matter of discussion, but by going by the properties to the east, we decided the answer was no. The road veers north, the property lines do not. There are properties on down caribou where the owners on the north side of the road, actually own small wedges of property on the south side of the road.  Lou told me that might be a matter for contention for some of those easterly south side owners one day.
Offline SwampDonkey
  • Large Tooth
« Reply #90 on: August 18, 2007, 04:48:53 pm »
Hey Jeff, the 1998 photo from MDNR shows some large cuts to the south, west and east of the property. Will post a snapshot in the 'Aerial Photo' thread. In the process of loading the Trout streams and lakes. Gotta find your fishing spot. ;D  :D :D
Dirty Harry
Offline Rockn H
  • long way to go
« Reply #91 on: August 30, 2007, 12:35:48 am »
Jeff, did you ever get the property surveyed.  If so does your property line actually cross one of the roads bordering your property.  I ask because here it is possible to have the road portion  removed from your property taxes at the accessors office, but your probably in a state that doesn't have that sort of thing anyway. ???
Offline Phorester
  • Can't have a healthy forest without cutting trees.
    • About Forestry Forum Host
« Reply #92 on: August 30, 2007, 10:46:52 am »
And the red star is.... beer joint..., ice cream stand...?
Interestingly enough, we have a bar in our town with the name of "The Red Star".  smiley_beertoast
About.Forestry.Com forum host. Ya'll come: http://forestry.about.com/mpboards.htm
Offline SwampDonkey
  • Large Tooth
« Reply #93 on: August 30, 2007, 05:18:06 pm »
Just guessing here, but he's probably getting ready to ride the trails this Sept and maybe getting ready for another bear hunt? There is a large set of buildings to the west of there and off to the right is something that has moved some earth, like a pit. Where the star is probably was in reference to the road? Kinda wet ground for a ice cream stand, although I see a couple here built up on fill on the edge of a swamp. You never know. ;) Why is it that gravel pits are next to wetlands?  :D :D
Dirty Harry
Offline Jeff
« Reply #94 on: August 30, 2007, 08:31:39 pm »
Nope, we decided that for now, there was no need for a survey. 3 lines are known, and the 4th, is of little matter at the present time.  :)
Offline Bogie
    • Minnesota Outdoors
« Reply #95 on: October 23, 2007, 09:01:29 pm »
I plan on having a surveyor do this later this year, but the one I am in contact with in the area winters in California and may not be back until early summer.
I know where two of the steel pins are for the corners of my property. The northwest corner, and the northeast corner.  The north and west sides of the property are bordered by roads, the east line is marked by what I am told is an actual survey, although probably 7 or 8 years old, on the property to the east. It is marked with some flagged chunks of conduit and cedar saplings turned into stakes.  That leaves the property line to the south as an unknown. With this information, should I be able to get pretty close to finding and marking that back line?  Lou Kurtis across the road, says he has all the stuff for running it that I can use. I'm not sure of the equipment names, but I think its a compass on a tripod that is set to the correct declination for that area, and also some sort of line measuring device that clips to your belt.
Jeff, have you ever used Goggle earth? we have found it to be very correct for measuring from a sattelite view. you do have better resolution in some areas than others. you can take a reading from your GPS and use the cordinates to locate it on the map.
Offline SwampDonkey
  • Large Tooth
« Reply #96 on: October 24, 2007, 05:54:27 am »
Jeff's Map Quest map seems to be a better quality image than the DNR aerial photo.  ::)
Dirty Harry
Offline Polly
« Reply #97 on: October 24, 2007, 05:08:05 pm »
 ;D ;D my new neighbor from way down south just bought 60 acres on north side of our property about 3 or4 months later he moved a section of original fence line which i know has been their at least the last 75 yearsabout 30 feet south of the original fence and then put up a sign no treaspassing  the only option i had was to hire a professional surveyor  i do not know his findings yet was i wrong  i stand to loose about one quarter of acre i think it is not amount of loss but the principal of the thing am i wrong :P :P 8)
Offline Ron Scott
    • Ron Scotts Web
« Reply #98 on: October 24, 2007, 06:37:56 pm »
Why did the new neighbor move the line?? Did they have a registered survey of their property? You did right by having your property surveyed to determine the correct ownership boundaries of record.
~Ron
Saw Anywhere!
