Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: New Nyle dh4000 Help  (Read 1615 times)
Offline MikeH
    • treefaller
« on: March 16, 2007, 05:59:46 pm »
  I have 3500bdft mostly quartersawn white and red oak and  some walnut ,all fresh off saw.  Guy at nyle tells me my load will get all stained if white not on top. I have read alot about kilns but not heard of this till kiln was full (not in manual) called woodmizer guy and he pretty much said dont worry about it. So now I not so freaked out or should I be. I have had my wood dried commercially in past and they sure dont sort it.
  The directions on the  kiln manual are in need of alot of help. Nyle guy told me to start at 90 degrees and 85% rh and bake wood every day I get home from work, I dont like to work in the kitchen and that is what I thought these low temp. kilns avoided. Woodmizer guy said start at 90degree and 85% rh  run it down to 60%rh up temp. to 100degree run down to 40% up temp. to 120degree till done. Sounds much easier.
  Okay now I have started Kiln at 90degree and 85%rh. Temp. keeps climbing to 95 ,I dump air out vent and know second time in 2nd day it climbed back to 95degrees. Question...can I pull to much water out with vent open and compressor running when rh is over 85 percent? or do I need to start baking wood right away.Any advise would help, Thanks.
 P.S. the kiln is very tight all linned in rubber and good seal on doors which take alot of effort to get in.         :)
Offline scsmith42
Re: New Nyle dh4000 Help
« Reply #1 on: March 16, 2007, 06:57:50 pm »
Mike, you didn't state your thicknesses, but with oak my experience is that you need to be careful about drying it too quickly.  The other problem is that at the lower temps mold can develop - especially if there is inadequate airflow through your stacks.  If you don't already have one, pick up an anemometer and check the airflow to make sure that it's within limits.
In my kiln the temp will vary a few degrees during the day, do you have access to a recording thermometer that will let you know what's happening while your away?  An extra 5 degrees initial temp shouldn't hurt you as long as your daily MC reduction is within limits, but the advice regarding checking your MC loss on a daily basis is sound (and yes you can dry to quickly with the vents open).  It's easy to mess up a load of oak, and with that much quartersawn you don't want to risk damaging it.  To be on the safe side, check your MC every day and adjust as needed.
I concur that the Nyle manual is not very clear or intuitive.
Offline MikeH
    • treefaller
« Reply #2 on: March 16, 2007, 07:22:35 pm »
 All the oak is 4/4 and walnut is 8/4 and looks like the 8/4 walnut will dry on a 4/4 white oak schedule of 2.5 m.c. loss per day.
Offline oakiemac
  • God bless the U.S.A!
    • Hickoryandoak
« Reply #3 on: March 16, 2007, 10:14:00 pm »
Mike,
I sure wouldnt mix 4/4 white oak with 8/4 walnut, especially green. If they were at hte same MC and dried to below 20% then it might be ok. I would be real leary of mixing up the different thickness like that.
White oak is one of the slowest drying and most challenging woods to dry. I'd set the schedule for the white oak and check the other stuff frequently.
Online Ga_Boy
  • Been rode hard and hung up wet; more than once.
« Reply #4 on: March 16, 2007, 11:58:32 pm »
Okie nailed it.  Dry it on a WO schedule and adjust the other species....
Hyster H80, Kubota B2710, Conventional Kiln, 2008 Corvette, AV-028 Super, MS361, MS460 Mag
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
« Reply #5 on: March 17, 2007, 01:45:12 pm »
First load should be something simple to dry.
No mix of thickness.  That can be done if wood is dryer than fiber saturation point (about 30%) bbbbut skip all that advanced stuff, keep it simple until you learn what you are doing.
I did weighed kiln samples for yrs. now I use the Kilmotroll.  Its whole concept takes allot of guesswork out and lets you verify spots in the kiln that dry quick and spots that dry slow.
The sweet spot in small scale kiln drying is to have a predry shed that works perfect,, then only dry 15%mc or less .
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
Offline Don_Lewis
  • dry kilns, heat pumps
    • nyle
« Reply #6 on: March 17, 2007, 09:00:03 pm »
I guess we need to work on the Manual. I thought it was pretty clear that you shouldn't mix species and thicknesses of green (over 25%) lumbre
I would let the temperature rise to about 100-105. Use the same RH settings.Check each day to be sure you are drying at the right rate. I know you were hoping to not have to do that but once you do and keep the records, you will have a lot better idea about what is going on. It is sort of like learning to make bread. Follow the recipe and then you develop a feel for it.\
Offline MikeH
    • treefaller
« Reply #7 on: March 17, 2007, 10:15:10 pm »
 I understand it is not recomended to mix species but have been having local lumber yard do it with good results in there 40mbf kiln. (red/white oak and hard maple).
 I cant wait for the day I can fill the kiln with 4000bdft. of quartered white oak.
        Thanks for your help.
        Mike
Offline Furby
  • Blurb....
« Reply #8 on: March 17, 2007, 10:39:19 pm »
Is the local lumber yard using the same type of kiln, and did they mix species on their first many loads or wait til they knew how the kiln worked?
Offline Don_Lewis
    • nyle
« Reply #9 on: March 18, 2007, 07:26:37 pm »
Mqple and Oak dry so differently from green that I can't think of any type of kiln that would give a good result with a mixed load. If it is below 25%, it all can be mixed
Offline MikeH
    • treefaller
« Reply #10 on: March 18, 2007, 11:10:42 pm »
Here is some pics of wood fresh off saw all dried together at Lake Elmo Hardwoods
 So can a nyle do this?
Offline Don_Lewis
    • nyle
« Reply #11 on: March 19, 2007, 02:50:32 pm »
The wood doesn't know what kind of system is making the temperature and humidity so the answer is "yes."
We have customers drying very high end figured Maple with L200's. In fact one has been doing it for years and is so successful, he is puting in 3 more larger chambers now.
Do you know what temperatures settings they use and are you certain the do not air dry the Oak?
Offline MikeH
    • treefaller
« Reply #12 on: March 19, 2007, 05:17:46 pm »
 No I dont know what temps. they used and they went out of business after 75 years, owner got sick and wife liquidated. So I was forced to buy kiln, I am sure it will work out just fine, I have not heard anything bad about nyle kilns. I am just looking for more recipes to do the cooking.
 Mike
« Reply #13 on: March 19, 2007, 10:04:24 pm »
You've been talking to "Mr. Nyle Kiln" himself.   If there are two people on this board that I would take their word for gospel, it would be Don Lewis and Den Socling.
Just because you think, or have been told, that your wood was dried in one load, doesn't mean that it was.   You may be finding out now just how technical an operation kiln operators are performing.   That's why they get the "big bucks".  :D
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #14 on: March 19, 2007, 11:26:37 pm »
You won't or can't get better advice then you will get from Don Lewis or Den Socling as mentioned and many of our other members for that matter, but Don and Den live and breath kiln drying and I would never dream of questioning thier advice. 8)
Offline Gary_C
  • Sunrise on the Prairie
« Reply #15 on: March 20, 2007, 12:18:43 am »
Mike
I was going to use that business to dry some wood until I talked to some others that had been drying wood there for years and did not get a good recommendation on them. But then they had their fire and I did not get a chance to try them.
But even so, they told me that if I brought in more than one species, I may have to wait longer because they would not mix species in a kiln load. I understand they sometimes pushed those steam kilns too much and had problems drying oaks.
At any rate, I have to agree with Jeff and Tom that when Don Lewis tells you something, you can bet on it. If Lake Elmo mixed species and got away with it, it was just luck and nothing else. From what I know their kilns were ready for retirement anyway.
Offline MikeH
    • treefaller
« Reply #16 on: March 20, 2007, 10:31:04 pm »
 I am sorry if  I upset the kiln gods, :-[ I was just looking for honest advise and now the board police are all over me.  ;D I read just about everything Don and Den wrote over the last five years under search words nyle and rh before I bought a kiln and after and respect their advise that is why I asked a question in the first place. I believe my original  question was can you take out to much water at over 85%rh at start of kiln when at low temp. I am looking for advise on kilns using rh instead of bulbs, why is everybody yelling at me for asking questions?
Offline Furby
  • Blurb....
« Reply #17 on: March 21, 2007, 12:39:10 am »
No one is yelling at you Mike, but you seem to have an attitude in your posts, and it's not being received very well by folks around here.
Might want to think through what you write a bit before you hit that post button. ;)
You were given some good advice in reply to your question.
You seem to ignore it as "you know better", that being the case, why ask questions?
Offline MikeH
    • treefaller
« Reply #18 on: March 21, 2007, 07:51:54 am »
 I am not very good at public speaking and must be worse at public typing. :) :) :)
Offline scsmith42
« Reply #19 on: March 21, 2007, 08:45:18 am »
<grin>  Mike - all that I can say is "GET IN LINE"!!
If I had a nickle for every time that something came across as different in writing than my intention, well I'd probably be sitting on a yacht somewhere sipping margaritas...
Don't sweat it.
Scott
Saw Anywhere!
