Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: walnut rootball  (Read 4569 times)
Offline WDH
  • April 1998 - August 2008
Re: walnut rootball
« Reply #40 on: March 30, 2007, 10:12:11 pm »
Raised panel doors and drawer faces..Yeh 8).
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline Daren
    • nelsonwoodworks
Re: walnut rootball
« Reply #41 on: March 30, 2007, 10:24:19 pm »
Daren  ;)
ps  did you run into rocks and how was the blade after cutting?
I bumped a few. You can see in the last picture if you look close I have a tooth or 2 pretty bad out of set, but I was still cutting good just leaving a scratch mark on the face. For some reason when I first started I was having gum problems on the blade and it was diving (rising hard actually ). The blade was sharp, just balling up with wood on the teeth. I guess it was because I am cutting with the grain, cross grain and everything in between. I cranked the tension down to the max and put some dish soap and water in the lube tank and really poured it on sawing, it fixed that problem.
I expect to hit a few rocks, but they should be on the leaving end not buried. I saw mostly yard trees...so as much as it makes me frustrated I am used to changing blades prematurely, I am like an Indy pit crew with as much practice as I get.
I may cut some thinner stock (?), but I have to saw on it some more. If I am changing blades every 4-5 cuts...4/4 just won't work. 10/4 is a safer bet first go around. This all an experiment to me. I think I have a market for the thicker stuff already, I have plenty of 4/4 figured stock to sell.
Experience is something you don't get until just after you need it.
Offline Robert Long
  • winner of WM Personal Best "GRAND CHAMPION" Cat. 6
    • www.portablesawmill.ca
Re: walnut rootball
« Reply #42 on: March 30, 2007, 10:32:45 pm »
Daren:
sounds like you've got it down to a science already, I am looking forward to my first root to mill and thanks to work already done my pros like you it will make my first one a "slice" so to speak :D
Robert
Offline WH_Conley
    • Stone Hill Hardwoods
Re: walnut rootball
« Reply #43 on: March 30, 2007, 10:35:42 pm »
Hey, let me know how all this works out. I have about 15 stumps that need to come out this spring.
( we could work out a deal). ;)
Bill
Offline dad2nine
  • If you aren't making mistakes, your not doing nothing
Re: walnut rootball
« Reply #44 on: April 01, 2007, 12:12:31 am »
As far a wild grain goes it doesn't get much better than root balls - but man what a pain in the A55 to cut.
Offline mburrow
Re: walnut rootball
« Reply #45 on: April 01, 2007, 12:59:29 am »
has anyone cut a white oak root ball I have this one, tree is still atached
Saw Anywhere!
