Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: The Farm Workshop. What tools do I need - starting from scratch.  (Read 2788 times)
Offline asy
  • Gender: Female
  • Errors have been made. Others will be blamed.
    • New You Forum, a forum dedicated to the Cohen Weight loss programme.
The question is:
What tools are ABSOLUTELY NECESSARY, and which ones are "Gee that'd be nice" to have on the farm.
So far we have all the little hand tools, so lets assume they're a given. You know, screwdrivers, hammers etc.
I also have a Bench Grinder and most of the little tools, like Drop saw, Drills, Hammer drills, Angle Grinder (4") and we're also taking a Radial Arm saw, nail gun and small compressor down there.
So...  What do we NEED?
I guess a welder would be high on the list (as discussed on another thread).
A wood lathe will be on the list as a 'want' not a 'need' I should imagine...
But what else?
asy :D
Never interrupt your opponent while he's making a mistake.
There cannot be a crisis next week. ~My schedule is already full..
Offline Larry
Re: The Farm Workshop. What tools do I need - starting from scratch.
« Reply #1 on: January 03, 2007, 05:38:06 pm »
Since the welder (electric?) is already a given I would suggest a chop saw…or maybe a metal cutting band saw.
Acetylene torch outfit would also be high on my list but you could get by with the electric welder.
Larry
Nine out of ten trees recommend wood for your building project.
Offline sawguy21
« Reply #2 on: January 03, 2007, 05:43:36 pm »
Do you have a set of mechanic's tools, box end wrenches (spanners?), socket sets, pliers and the like? They will be indispensible around machinery. You won't need Proto or Snap-On although they are sure nice but don't waste your money on the cheap imports. A 4"-6" bench vise is mandatory. An electric drive 5hp air compressor with a 60 gallon reservoir is almost a must have too. Don't go too small here. A good axe and a maul would also be useful. Gee, shopping with other people's money is fun. 8)
Offline DanG
« Reply #3 on: January 03, 2007, 05:50:23 pm »
Wrenches.  Lots of'em, including sockets in both SAE and Metric.  The air compressor is vital, imho, because it enables you to get some air operated tools.  They are cheap, but worth their weight in gold! 8) 8)  Several good heavy duty jacks and plenty of wood blocks are always handy around tractors.  You got two of them beasts, so go get a  greasegun NOW if you don't already have one.
More later.  Gotta go feed animals before it gets too dark. :-\
Offline woodmills1
  • the truth shall set you free
« Reply #4 on: January 03, 2007, 05:55:38 pm »
listen to all the previous.  Mechanics tools go used but not of of brands.  Junk metal tools only used for the one time job.  For wood need table saw, jointer, planer and chop or radial arm,  get the lathe and theshaper later.
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #5 on: January 03, 2007, 06:18:37 pm »
For the handtools add 3/4 drive socket set.   1/2 inch at minimum.  Working on large equipment necessitates a large set, including a big breaker bar and the matching pipe section.  ;D
I agree with the cutting torch, metal chop saw and welder at the top of the list.  Here's a few other items in no particular order:
Digging bar
chain saw
pick
fence pliers
wire stretcher
pruners
circular saw (battery op)
     or lots of extension cords
generator
crow bar
drill press
screw gun
lots of hammers ( I never have one where I need it)
highlift jack
bolt cutters
Hidden Acres Farm
I got a shotgun, a shovel backhoe and 57 acres!
Wood-Mizer LT40HDG25
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #6 on: January 03, 2007, 06:24:02 pm »
Drill press and a bench grinder and I'd get a set of torches when I picked up the new welder.  Gear pullers are also good things to have around.  You may seldom need them but they sure make life easier when you do ;)  Good pipe wrenches up to 24".  I'd start the set at 8"  ;)  An assortment of crowbars, pinch bars etc.  Don't forget cold chisels, center punches and drifts.
« Reply #7 on: January 03, 2007, 06:43:10 pm »
Nails, screws, Rope (200' 1/8" poly and 100' 1/2" nylon--larger as you learn), chain, Cold Shuts, Assorted bolts, washers and nuts.   A pile of scrap metal for making things fit. (don't ever throw anything away.) chainsaw.  Keep a spool of twine in each vehicle.
(you can do a lot of building with nails, rough wood and a chainsaw.)
Electric wire from 20 gauge on up 4.  Electric tape.
Post hole diggers, handsaw (bowsaw).
Having a sawmill will provide you with a lot of building material.  plan on using wood for most initial building because it will be available.
Tub of grease and a grease gun. (use it. The world runs on grease)
Several cases of engine oil at least one change per vehicle.
accumulate a set of filters for all vehicles.
At least 10 gallons of hydraulic oil.
4 or 5 inexpensive tarpolins.
buy your work gloves by the gross from a safety type company.  You can usually find them for 1 or 2 dollars a pair. (split leather and canvas)  cotton gloves catch on wood and metal.
A tire repair kit. Patches, plugs, air gauge, portable air bottle.
5 gallon water cooler, cups (travel cups for the tractor)
25 gallon cooler for lunches
a bunch of ammunition boxes of the 30 caliber size for small sets of tools for the tractor or chainsaw or to carry spare parts in the truck.
Hats!!  Don't rely on caps.  Use brimmed hats whether straw or cloth to keep the cancerous rays off of your ears and neck.  Straw is cheap, light and cool.  Buy them 5 or six to each person so that store inventory won't get you out of the habit of wearing them.
Get in the habit of wearing long sleave shirts and sun protection.
Eveyone one on the farm should carry a sharp pocket knife and know how to keep it sharp.  There is no problem with carrying two if you also need a cheap utility knife.
Learn to use them in a safe manner.
Keep first aid kits in close proximity to all work being done.   Own several and keep them current.
Flash lights (electric torches) for each vehicle.
Learn to tie good knots
learn to rig and handle heavy loads
Never reach into something that is moving
Don't spend more than half of what you have in your pocket. ;D
Offline Riles
« Reply #8 on: January 03, 2007, 06:52:59 pm »
I like that. 25 gallon cooler for lunches.  :o  None of those namby-pamby six-pack sized lunch buckets. How many people ya feedin' there Tom?
Knowledge is good -- Faber College
« Reply #9 on: January 03, 2007, 07:11:58 pm »
..................one. (?) :D
Offline badpenny
  • Go green recycle Congress
« Reply #10 on: January 03, 2007, 07:23:45 pm »
  We used to call them "Herman Munster" lunchboxes
Hope and Change, my foot,  It's time for Action and Results!
Offline Don_Papenburg
  • I need
« Reply #11 on: January 03, 2007, 07:53:08 pm »
ONE of the MOST INDISPENSABLE tools is a flat smooth concrete floor.  It makes the other tools work much more efficiantly.
 Drill press
grinder
welder
Greese gun   Look for a MacNaught  Mini lube or Maxi lube  Maxi lube fits 5galon pail.  I wish I had a maxi lube . I have the Mini  Got it at a farm show back in the early 80s  It is made right there in the land of OZ.
Offline Stump Jumper
    • Hernden's Sawing & Excavating
« Reply #12 on: January 03, 2007, 08:10:48 pm »
rust reaper  ;)
the farm doesn't have house yet  ??? so an outhouse is a good tool  eh eh
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #13 on: January 03, 2007, 08:41:07 pm »
  A half a dozen chain holes ,  and maybe a sky hook ,  are things that you will be looking for in the near futur .
   Marcel
Offline thecfarm
« Reply #14 on: January 03, 2007, 08:45:04 pm »
Ladder,step ladder,sawmill  :D steel flat shovel.Chains and straps to pull out trucks,cars when they get stuck.Start checking lawnsales and auctions for nuts and bolts.Why don't you just come on by with a note pad.Be alot eaiser.  :D
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline Corley5
    • Whittaker Farms
« Reply #15 on: January 03, 2007, 08:49:49 pm »
A selection of LogRite tools of course.  I'd start out with a 48" canthook and a 42" hookaroon  ;) ;D  Probably oughta have a one of their logscales too
Offline PineNut
« Reply #16 on: January 03, 2007, 09:14:54 pm »
Don’t forget electric fence wire. It replaces bailing wire for those emergency temporary repairs.
  • I need
« Reply #17 on: January 03, 2007, 09:39:59 pm »
Hey Stump Jumper ,How could I have forgotten the outhouse ?  That is the first thing I built on my farm .  Brick one holer with armrests to make the reading easier . Raised panel seat skirt for added class.
Offline SwampDonkey
  • Large Tooth
« Reply #18 on: January 03, 2007, 09:57:35 pm »
Tap and die set for threading or rethreading bolts and nuts.
Dirty Harry
Offline pigman
« Reply #19 on: January 03, 2007, 10:39:53 pm »
A large strong building  with  good locking doors to store all of the tools mentioned.
Bob
Saw Anywhere!
