Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: What About Vines?  (Read 1997 times)
Offline tcsmpsi
  • Time is relevant, only because it exists.
    • The Custom Shop/MPSI
What About Vines?
« on: October 24, 2006, 10:31:37 am »
Are they completely detrimental to trees?  Do they have any redeeming aspect?
I am sure that they have ecological benefit.  Indeed, grape vines produce grapes.
I have VINES.  I see some that are 3-4" diameter at the base.
I have hardly any trees without a full compliment of vines.  Primarily, the trees are about 28-30 yr old SYP, but quite a few various hardwoods scattered about.  And, there is a notable amount of older growth.
Certainly, I wish to keep the trees I can and thin for milling as time goes on.
Is there any benefit to keeping some vines?   Or, should I work on deleting them all?
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
Offline Michigan Mike
Re: What About Vines?
« Reply #1 on: October 24, 2006, 03:34:26 pm »
  This is kind of second hand information. When I had a forester out to look at my small woodlot I asked him the same question. He wasent too concerned with the vines that were tight to the trunk of the tree [virgina creeper, poisen ivey] but grape vines and others that hung from the branches were somthing that he would prefer  to remove.
Offline beenthere
  • EIEIO
« Reply #2 on: October 24, 2006, 04:05:01 pm »
Around here (southern WI) virginia creeper will choke a tree to death. I remove all vines with a death chop. Seems within 5 years, the VC vine will get big enough to start to degrade the crown of a tree.
Not sure about the South, but suspect they can't be good for a tree. Just may not kill it.
Offline Texas Ranger
  • Texan, by God and by choice.
    • Staples Forestry
« Reply #3 on: October 24, 2006, 04:10:23 pm »
what mike said, and a series of light control burns will control the vines.
Offline crtreedude
  • A proper coffee break...
    • Finca Leola Reforestation
« Reply #4 on: October 24, 2006, 04:13:27 pm »
We have something called a stranglerfig down here. The birds love these wild figs, grab the fruits and take them to another tree to eat, and of course deposite the seeds in the top of the trees. These stranglers send down roots, like 100 feet or more to the ground and then start thicking up. Eventually, they completely encircle the tree and strangle it.
Often you will see what looks like a tree, but in reality, it is a bunch of these vines fused together. Another name for a stranglerfig is matapalo (tree killer)
So, how did I end up here anyway?
Offline tcsmpsi
« Reply #5 on: October 24, 2006, 05:02:47 pm »
Oh, they'll kill it alright, beenthere, cut a tree right into, they will.
I've been working on getting many of them cut, been kinda wanting to get a feel if there is any notable benefit in allowing some to stay.  I don't personally see any benefit (treewise, anyhow).  Shame that it has pretty much come down to vineocide.
Offline LOGDOG
« Reply #6 on: October 24, 2006, 05:50:31 pm »
Hey TCSMPSI,
   Maybe after hunting season closes up there in WI you can invite BEENTHERE down for a visit with his shotgun. He'll make quick work of those vines.  :D Sorry BEENTHERE ...couldn't resist. ;D
LOGDOG
Offline SPIKER
« Reply #7 on: October 24, 2006, 06:01:43 pm »
While grapes and a few other types of vines HANG from the branches upper stories, these tend to harm the tree by several ways, (added weight causes tree to lean / deform, ice rain & wind cause more damage to tree that is heavy with vines too)
my forester wanted all grapes cut that were in the forest story for production trees.   but leaving some in small areas for wild life is great.   birds squirls deep all like the grapes where they ahve already caused a bunch of damage to smaller confined area it can be left for wildlife habitate.     keeping the production areas clear is required for good stand management.
as someone stated tight clinging vines are ok BUT can cause some light problems and also may cause wood problems if the tree is heavy infected the wood can be damaged by the vine roots attashing as well as the loss of light/food/water.
I personally hate the vines as walking is harder around them, and woman is bad for Poisen Ivy. (It don't bug me other than hating the vines).   honeysuckel & some other types will also strangle the tree out.   ause sevier sapling damage and loss of nutrients for trees.
when indoupt I say remove them.
don't try & pull out vines from tree tops, chances are you will cause MORE damage to the tree than letting the vines drop on their own.   (not to mention can be dangerous.)
also when you CUT the vine, cut out a section 3~5' worth, from groud level up to head + height. so you can visually SEE that the vines have been cut.   they will drop after a few years, make sure to go back & re-cut vines often to maintain them dead/cut.   I like to carry my machete with me for most vines as it cuts them well.  even thick grape vines, though I used a small 14" poulan chain saw for them initially as cutting 2~5" dia vines is a challange...   the saw I use is very light and was cheap.   I can carry it along through woods cutting.   also cut woods in a grid like pattern so as to not miss stuff that you want to remove.   besure to leave one~two areas with vines for critters.
MarkM
Offline beenthere
  • EIEIO
« Reply #8 on: October 24, 2006, 06:03:20 pm »
 ;D
Change the name to Paladin.....
Offline tcsmpsi
« Reply #9 on: October 24, 2006, 06:12:21 pm »
I ain't supplying the shells.  Well, maybe I would supply the first case.
Last several weekends, it has been the ongoing chore for the yet at home male teenage recycling plant to cut vines.  Low pressure, virtual job.   :D
I am not real happy about losing so many muscadines, but then, there way more than I had time and opportunity to process  (though I do manage to personally recycle many pounds of them every year).  ;D
Offline PineNut
« Reply #10 on: October 24, 2006, 08:23:39 pm »
Have a lot of problem with Wisteria here in MS.  Looks pretty in early spring but is bad on trees. Small vines get a spray treatment and the larger ones (2 to 4 inches) get cut off and the stumps get a treatment.  I agree about cutting out a section so you can see where you have been cutting.
Offline tcsmpsi
« Reply #11 on: October 25, 2006, 08:13:27 am »
Over the years, I've always had to cut a few vines here and there (just to walk through some areas), and have always cut the vines up as far as safely possible, more to be able to get around than anything else.
Now, I'm having to take a serious view of vines throughout the property, now that trees, individually and collectively, are of a more notable concern.  Whereas, the natural environment of the property was more of a priority in the past.
I will probably be leaving some grape vines here and there, but otherwise, and from input here, will be giving more carte blanch to the vine cutting process.  There are a few trees which the vines have already cut tops out of.
Offline Ron Scott
    • Ron Scotts Web
« Reply #12 on: October 25, 2006, 10:10:21 am »
Yes, to maintain and improve your wildlife habitat, leave a few "selected" grape vines for wildlife. Leave about 1-4/acre that are not really affecting good quality trees.
~Ron
Offline tcsmpsi
« Reply #13 on: October 25, 2006, 10:41:17 am »
Yep.  Leaving some of those is most especially of importance since I am one of the muscadine eating wildlife.   ;D
Offline rebocardo
  • Atlanta GA
« Reply #14 on: October 28, 2006, 02:29:32 pm »
From what I have seen is the vines themselves sometimes are not the problem. They harbor ants that can travel under the vines unmolested by the birds and build colonies in the trees without getting attacked.
Offline tcsmpsi
« Reply #15 on: October 30, 2006, 05:34:05 pm »
The most immediate problem with the vines here (large 2-4" base) is their wrapping themselves around the tree and cutting off its existence.  They are tough and maintain a large diameter throughout growth.  Some of these vines grow phenomenonally.   As random example, one (2" diameter) I had cut about  2' from ground around mid April, by mid June had already sprouted 20-30 shoots 5-7' in length.
Offline pineywoods
« Reply #16 on: October 30, 2006, 08:39:43 pm »
Is that why east Texas is known as "the big thicket" ?????
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline tcsmpsi
« Reply #17 on: October 31, 2006, 07:19:44 am »
A significant part, along with yaupons, briars and thorntrees.  I think there's not but one grandfather yaupon root in all of The Big Thicket.   :D
Offline Larry
« Reply #18 on: October 31, 2006, 07:39:31 am »
I carry a little squirt spray bottle to treat the cut vines with herbicide.  Well worth the little extra work as you won't have to go back for maybe 5 years.
Larry
Nine out of ten trees recommend wood for your building project.
Online WDH
  • April 1998 - August 2008
« Reply #19 on: November 01, 2006, 11:27:54 am »
Ditto what Larry said.......
I carry a Formula 409 spray bottle, one with the little lever that you can use to squirt herbicide into a hatchet cut.  Just hack the vine and squirt in the herbicide in the cut.  Just take care not to get the herbicide on the host tree.  I have done hundreds this way.  Grapevine just needs a whiff of the herbicide, and it is a goner.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Saw Anywhere!
