depends on a few things, one, are you running direct? from the engine to the blade? or Pump? flywheel?
Easiest would be to set up a tach, run the accelerator cable on a limiting block.
An adjustable Cable pull, like for throttle body... pull out and dial it in to get your RPMS, then set it and go.
Pictures pictures.
Jack
