Get your Forestry Forum Hats while they last!
Looks like you have a good solution for getting water off a woods road and still allow vehicles to travel, but just to comment on water bars........... they were never intended to be used on roads which would be used for vehicular traffic. They should be used only on roads and skid trails that are permently closed off. On woods roads where vehicles will continue to be driven, we use rolling dips. These are mounds of dirt placed exactly as a water bar; at an angle to the road to divert water off, and maybe a little higher than a water bar to be more maintenance free. But they are shaped wider than a water bar and gently sloped on both sides so a vehicle will "roll" up and over them like going over a low hill, which is basically what they are. A rule of thumb we use is if a bulldozer's tracks stay on the ground the entire width of a rolling dip as it travels over it, it is installed right. If the dozer "flops" over one, where the front end raises up off the ground until the back end gets far enough over the mound of dirt so the front end slams down, (like it does going over a water bar) it is too narrow and needs to be reshaped. Rolling dips are permanent, easy to drive over, and if installed as described above and at proper spacing according to % slope, they are practically maintenance free. Not critizing your idea, I like it, just commenting on water bars.
