Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: pole barn in ground part treatment?  (Read 2752 times)
Offline firecord
  • I'll try anything once
Re: pole barn in ground part treatment?
« Reply #20 on: July 27, 2006, 02:25:23 pm »
My buddy has a shed built with pine poles, been in ground for 30 years.  NO ROT AT ALL.   Dug hole 2 foot deeper than desired, filled to post hight with gravel.  Soaked pole ends in mixture of diesel and old oil before concreting over the gravel.  Ofcoarse I don't think the EPA would approve.
Offline thecfarm
« Reply #21 on: July 27, 2006, 10:14:58 pm »
Hello firecord and welcome to the forum.Update your profile and tell us where you are from.Don't be afraid to take a few pictures of that sawmill you are building.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline Don P
    • Calculator Index
« Reply #22 on: July 27, 2006, 10:51:12 pm »
This is another way, the concrete finishing leaves alot to be desired  ::). The bottom plate has rebar welded to the bottom and is set in the fresh concrete. The upper flat plate with the knifeplate welded to it is inserted in the end of the post, drilled thru post and vertical knifeplate, and then pinned. The post is located and the plates then welded together.
Offline Don P
    • Calculator Index
« Reply #23 on: July 28, 2006, 10:09:35 pm »
That's what I get for taking a picture of that tube. We started the porch today, not sure what happened but that sucker is several inches off. I did the layout and the homeowner did the pour, sweat equity. I showed it to him this morning and raised my hand, thankfully he has a sense of humor. Monday my name is going to be John Henry  :-[.
 Measure twice, pour once
          or
Measure once, pour twice ::)
Saw Anywhere!
