Get your Forestry Forum Hats while they last!
The cam rollers were replaced on my mill during the platinum service at 2600 hours. I was told that the groove that wears in them can actually misform the outer race of the needle bearing thereby causing problems. Mine looked just about like yours, Bibby, if not a bit worse. Mine are carrying the 42 HP Kubota Diesel, probably a bit heavier than the 25HP electric motor. Ilooks like 2500 hours would be a good time to replace them on 40 supers.
Oh yea, I learned that when tightening the rocker with the two rollers on 40 supers, don't forget to put the weight of the head on it first, so the rocker is level.
Bibby-Are those aluminum bushings Woodmizer?
