I need to add something to this .
I awoke last night, wide eyed, that I hadn't mentioned it.
To transplant pines, especially seedlings, it is a Dormant Period job. The latest in Florida is March first.
If you transplant in a period other than dormancy, success will be minimal.
I don't want to lead you down a wrong road. To find the period best for transplant in your area, you need to talk to your county agent or County Forester.
The reason I don't like the idea of scooping up larger trees is that the taproot could be cut off. Cutting the taproot off is paramount to "topping" the tree. Sometimes they well generate a new "leader" and sometimes they won't. When they do, the form and strength is compromised.
If you are within the planting time for your area, I still recommend the seedlings. You might even be able to buy some from your State Nursery through your Forester. You would be assured of species and genetic superiority that way. They aren't expensive.
