Get your Forestry Forum Hats while they last!
Soak it in a pond
Only these observations.It wasn't at 38.25% to begin with. (perhaps it was mismeasured, came from the interior of a stack or was just not dried enough.)It took on water.Wood reaches equilibrium with the ambiant moisture. Even when dried, it may slowly take on moisture until it is in balance with the surrounding water content.Lastly,I'm glad I don't live where the first choice of a person is to call legal authorities. We may be headed that way but most people still will talk with one another first and go to the law as a last resort.
I suspect it could be because of less than subjective testing. In the one scan it says something to the effect of "average surface moisture" in the other it doesn't say at all how the reading was obtained.I don't think it would be too hard to get a surface reading of 38% from moist bark, in fact you could probably get that reading from wood that is less than 10% inside.
Not without knowing what was tested, when, and how. If both tests were the oven dry method, then I would suspect soaking as Corley5 suggested, or not dry to begin with (tested separate pieces). If either reading was with a meter, the meter reading is not a valid mc reading. Both indicate moisture over 28%, but an actual reading from a moisture meter of how much over 28% cannot be determined. Just my thoughts and opinion.
I saw what I think was your post on another board. You described a 2 year harvest. The wood was cut to length and piled the first year and split and delivered the next. I think that first the sample sizes were probably inadequate to say that the avereage went up. and then I think some of the wood was probably composting in the shell inside the pile. If the authorities, I didn't know there was such a thing for firewood, are adamant about policing it, can you cut and split the first year?
Seems like the investigaters had some experience, but, wood products is not a common subject among police, or agencies. If the seller was smart, he would have an investigater or attourney pick u p some of the wood and have it tested by folks that know wood.
For your own good and knowledge of your firewood product, I sure hope you are doing the oven dry test method to know the true answer.
Is that law or rule still in effect? That was 11 years ago and thought I saw where the wood rules were repealed in '95 or so.
How can you tell that? without measuring mc with meter or oven?
