Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: saw rpm?  (Read 743 times)
Offline minesmoria
saw rpm?
« on: April 12, 2006, 10:22:48 pm »
I have an husky 359 i was adjusting the  hi speed with the techometer  it sounded  better around 12700 instead of 13500
I also have a dual port muffler would this affect the speed?
Offline ehp
    • ehpsaws.com
Re: saw rpm?
« Reply #1 on: April 12, 2006, 11:42:38 pm »
I believe you are alot closer to the stock rpm'swith the 12700 cause I know for my area they call for 12500 rpms stock, my ported 359's run around 13800 to 14200  so 13500 on a stock porting would be to high in my books
Offline minesmoria
husky 359 rpm??
« Reply #2 on: April 13, 2006, 12:21:10 am »
The  359  manual  specs says 13500 hi speed, so you think i should run higher 14000 would this not kill the  cylinder over time to fast for engine design?
Offline ehp
    • ehpsaws.com
Re: saw rpm?
« Reply #3 on: April 13, 2006, 12:14:52 pm »
no I said you should turn lower, my ported 359's are higher but they are ported , I found around 13000 rpms on a stock 359 worked better and gave you more torque , most of the 359's are to lean to suit me so I make the carb adjustable and set them alittle richer
Offline snowshoveler
  • Knotty Knot Sawmill
Re: saw rpm?
« Reply #4 on: April 13, 2006, 05:13:35 pm »
stock 359s im my area will tolerate 13500 plus rpm for a short while, but will eventually blow the piston ring retaining pin through the top of the piston. after that its gets a little messy.
we try to keep them below 13500 .
but with the dumbheads here with 15 inch bars and dull 325 chains those poor saws dont stand much of a chance.
they just scream all the time.
im curious now do most of you run the 72 or 73 chain or do you use the 325 chain.
the stickers on the saws spec the 72 chain but they arrive to us with the 325 rim sprocket installed .
i have switched a few over for customers and they are happy .
i think they have enough power for the large chain.
chris
International T5 dozer
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
Offline minesmoria
Re: saw rpm?
« Reply #5 on: April 13, 2006, 09:14:51 pm »
I run 73 full skip chain works great, is there any real difference in .325 vs 3/8
Offline sawguy21
Re: saw rpm?
« Reply #6 on: April 13, 2006, 10:06:43 pm »
When I sold Husky, the 359 came in with 3/8 rims and the 73LP  worked well. It would probably scream with 95VP. However, for some reason, we got 55 Ranchers with .325 rims and 3/8 bars, we switched to 3/8 rims.
Offline ehp
    • ehpsaws.com
Re: saw rpm?
« Reply #7 on: April 13, 2006, 10:50:09 pm »
all 359's here come with 3/8's chain on them , most come with a 20 inch bar which is kind of big for our area , a 16 inch or 18 inch bar is better . I have ran alot of 359's both stock a modded and I find the stock 359 is ok cutting smaller softer wood but when you start cutting bigger maple and beech it is to lean with the carb set as rich as it can go on the carb limiter caps and you could blow the motor up real easy but if you grind the little ear off the cap so you can set the high speed jet alittle richer they work fine
Offline minesmoria
Re: saw rpm?
« Reply #8 on: April 14, 2006, 12:09:27 am »
Yup i did cut the caps right off the carb i think i will keep  rpm 12700 works fine cutting 36"  yellow ceder logs.
Re: saw rpm?
« Reply #9 on: April 14, 2006, 10:26:27 am »
here is the tip of the day folks...
when you need to adjust the carb on a "locked carb",you dont have to grind, alter or otherwise mess with the locks.
you just use a flat blade screwdriver and move the lock about 1/16 inch off the needle.
now it is unlocked,you can use a smaller screwdriver "we made 1 from a normal carb adjustment screwdriver "
its 1/2 as narrow.
the NEW screwdriver will fit through the middle of the lock and you can adjust the needle directly.
when finished simply push the lock back on and nobody will know you were there.
chris
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
Saw Anywhere!
