Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Oil on winch clutch plate  (Read 673 times)
Offline micky boy
« on: April 11, 2006, 04:42:07 pm »
Hi, I am working with an Igland 5002 double drum three point linkage winch. Recently had a seal blow and oil got on the clutch plate. The plate is double sided.
What is the best way to get the oil off ?
Can it be cleaned and very lightly ground with an abrasive wheel or is that pointless ?
Many thanks
Three Five Seven............Chainsaw Heaven
Offline wiam
Re: Oil on winch clutch plate
« Reply #1 on: April 11, 2006, 05:13:56 pm »
You might try brake clean and a wire brush.
Will
Offline JimBuis
« Reply #2 on: April 11, 2006, 05:20:27 pm »
I would try an aerosol electronic parts cleaner.  That stuff eats EVERYTHING petroleum based like nothing.  I evaporates very quickly leaving no residue behind except, in this case, the oil.  I doubt that any brushing or other abrasive would be necessary.  When using the stuff, make sure you aren't smoking as the stuff is more flammable/explosive than anything else I know of.
IMHO,
Jim
Jim Buis                             Peterson 10" WPF swingmill
Offline scsmith42
« Reply #3 on: April 11, 2006, 05:27:53 pm »
MEK works well (Methyl Ethyl Ketone); the local aircraft repair shop used to use it to clean everything.  Spray carb cleaner, spray electrical contact cleaner, or spray brake cleaner are also good choices as recommended by others.  Of the three, spray brake cleaner is tested not to hurt the abrasive materials on the plates, so that would be my first choice.
Offline Reddog
« Reply #4 on: April 11, 2006, 05:46:34 pm »
brake clean will work the best.
Offline sawguy21
« Reply #5 on: April 11, 2006, 08:55:56 pm »
MEK is no longer legal to use here. That stuff cleans really well but is nasty to work with. Brake cleaner is not petroleum based so would be a good choice.
Offline Nova
« Reply #6 on: April 12, 2006, 07:37:34 am »
Further to MEK.  Don't get it in your eyes.  I worked with a guy who did and he had to have a corneal transplant because the MEK burned his cornea and blinded him.  He's very lucky that he can see again.
Nova
...No one cares how much you know until they know how much you care...John Maxwell
Offline micky boy
« Reply #7 on: April 12, 2006, 04:07:48 pm »
Thanks, most of you say brake cleaner so I'll go with that.   That MEK sounds a bit too much of a health hazard.
Saw Anywhere!
