Get your Forestry Forum Hats while they last!
Loop the log with the deadheader pointed towards the front, then run the winch and pull/lift off the back.
If you are tying against a tree and dragging the trailer out from under the log, be sure to use a binder of some sort to let the load off of the chain, or you will end up with a log on the ground with a chain too tight to let the hooks off. (don't ask me how I learned this....)
Red Pill,It's my understanding that you use the deadheader in reverse. Loop the log with the deadheader pointed towards the front, then run the winch and pull/lift off the back.Welcome to the forum!
