Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Poll
What type of mill do you run?
Thin kerf bandmill
713 (67.5%)
Swing blade mill
99 (9.4%)
Dimension mill
29 (2.7%)
Circle hand mill
112 (10.6%)
Circle automatic
27 (2.6%)
Other
77 (7.3%)
Total Members Voted: 983
Author Topic: Iron Inventory  (Read 120358 times)
Offline thecfarm
Re: Iron Inventory
« Reply #460 on: January 09, 2012, 06:21:21 am »
First sawmill? What's all the lumber going to be used for. Looks like you have an off bearer waiting for you to get sawing.  ;D
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline locdogg
Re: Iron Inventory
« Reply #461 on: January 09, 2012, 08:26:17 am »
I will use it to hopefully do some custom milling and make boards for my own woodworking.  yeah my off-bearers will be sad when those bales are gone.  ;D it sure keeps them busy while i mess around.  and it keeps them away from the sawmill.
Offline woodyone.john
Re: Iron Inventory
« Reply #462 on: January 18, 2012, 03:32:49 am »
wm 40 super  [the toughest misstress to keep sweet, perhaps i never learnt] and 10 inch peterson [the most physical days work you can get]
when all is said and done more has been said than done
Online rlahaise
Re: Iron Inventory
« Reply #463 on: January 19, 2012, 06:09:41 pm »
Hi.
Been lurking here for a while and finally picked up a used home built mill..
27hp liquid cooled Kawasaki engine, 35' track with 24" wheels.. Have milled 2 logs before the weather chased me inside and as soon as these -20ish temps are gone I'll be back at it.
Already thinking about modifications, need to build a simple log dog system as it now uses turnbuckles with a set of teeth at one end.. track had to be cut to transport so hinging it where I made the cut is a possibility so I can put a axle under it and transport it..
Want to build a sharpener and setter at some point as well but for now I will be looking for a local place that sharpens.. I am told WoodMizer will only sharpen their own blades and I have about a dozen 1 1/2" Lenox blades..
Pic in my gallery I just cant seem to attach it to this message??
looking forward to learning from the group.
Cheers
Rod
Offline FeltzE
  • Fayetteville NC, Stop by and visit some time!
    • Feltz's Sawmill
Re: Iron Inventory
« Reply #464 on: January 20, 2012, 06:24:43 am »
Just an update
Samill:
WM LT40 HDG35
Baker Edger
Sharpening:
Cooks cat claw
Cooks Single tooth setter
Grizzly grinder for planer blades up to 20"
Viel profile grinder
Kiln:
Nyle L200
Shop:
Grizzly 20" Planer
RBI 20" Planer/Moulder
Logosol 261 4 sided moulder
Grizzly 3hp shaper with power feed
Off Brand 3/4 hp shaper
Handling
GMC 6500 flatbed dump
Cat 416 4wd backhoe w/forks
Cat D3 widetrack
New Holland 4wd 48hp tractor with forks
Dodge 1 ton with 20ft trailer
CONSIDERING .... 20" Shavings machine.....?????
Offline Cypress Sam
  • ON Bayou Bartholomew
Re: Iron Inventory
« Reply #465 on: January 29, 2012, 03:57:26 pm »
LT 35, JD 4630, various loaders
SAM
Offline Tim Lea
Re: Iron Inventory
« Reply #466 on: February 02, 2012, 12:49:37 pm »
Wood-Mizer LT40
Offline Meadows Miller
  • The Walkabout Sawyer
Re: Iron Inventory
« Reply #467 on: February 03, 2012, 09:16:37 am »
Gday
and Welcome to The Forum Sam and Tim  ;) ;D ;D 8) 8) so are you fellas working your mills fultime or partime tell us abit about yourselves and we like pic to round here  ;) ;D
FeltzE you got some gear Mate  :o :) ;) :D ;D 8) 8)
Regards Chris
Jackson Lumber Harvester RMP 50" Manual Circular Mill #132 with Jackson Lumber Harvester Portable Edger, Meadows #2 delux manual circular sawmill & Edger, 1997 International 4700 Flatbed
Offline Magicman
  • Knothole Sawmill, LLC
Re: Iron Inventory
« Reply #468 on: February 03, 2012, 10:04:11 am »
Welcome Cypress Sam and Tim Lea.  It sounds like you need to give us an introduction.   :)
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline DanHicks
  • Member*
  • lt10
Re: Iron Inventory
« Reply #469 on: February 17, 2012, 06:03:51 pm »
wm lt10
Offline ALWOL
Re: Iron Inventory
« Reply #470 on: February 29, 2012, 12:10:00 pm »
   I joined the forum a few days ago and just now discovered this thread. I have a Fisher and Davis hand set circular mill that was made in 1889, and a Kingsland and Douglas hand set circular mill that was made about 1900 and has been mounted on a pair of old truck frames with an axle to be portable. I power the portable with a flat belt from a John Deere tractor, and the Fisher and Davis has a D8800 Cat power unit, that still needs to be connected.
   I wish that I had found this site several years ago when I was setting up my first mill. There is a wealth of knowledge here that has been a big help.
   I do not do a lot of sawing, mainly for friends and neighbors and myself, but I sure do like the sound of a saw singing through a Walnut with the JD 720 up against the governor.
      Alan
Offline markd
Re: Iron Inventory
« Reply #471 on: March 07, 2012, 10:08:41 am »
50" hand set make unknown v6 gmc terra flo power hydraulic carriage and turner, ooowee mean sawdust machine!
markd
Offline dblair
Re: Iron Inventory
« Reply #472 on: March 15, 2012, 10:36:16 am »
1935 Appomattox circle mill and a homebuilt bandsaw .
Offline markd
Re: Iron Inventory
« Reply #473 on: March 15, 2012, 10:48:39 am »
Looks sunny and warm there, raining cats and dogs here. nice building over the mill you sawed it  I'll bet. what powers your circle mill? Is that a nice old Oliver tractor on the band? Are those pine trees in the background?
markd
Offline dblair
Re: Iron Inventory
« Reply #474 on: March 15, 2012, 06:55:58 pm »
it was a nice day that day about 55 degrees , it's been a lot warmer than that lately into the 80's . that old circle mill is a minn moline 403 and about 75 hp at 1260 rpm . that's the speed we run and it turns the mandrel 580 rpm on a 48 inch blade . yes, we sawed all the lumber but not all of it came from our pines some came from neighbors trees they gave us. I hate to cut mine unless we have to. the Oliver 66 is one of our pullers I had parked there when the pic was taken . the bandmill has a 5 hp electric on it .
Offline Iron Mtn Scott
Re: Iron Inventory
« Reply #475 on: March 21, 2012, 11:35:47 pm »
Runnin' a Lucas 8-25, have a slabbing attachment. (ain't mustered up the courage to put that on yet but theres a scary lookin' black walnut 5' butt log sitting nearby the mill callin' my name.) ... or was it callin' me names?
Offline Bert
Re: Iron Inventory
« Reply #476 on: March 23, 2012, 08:34:47 am »
Hi All. I've been on here for awhile but never divulged the scale of our operations. We are a slightly more than part time, slightly less than full time operation. I've never been one to put all my eggs and 1 basket. We are running a 225 timberjack and IH Fleetstar with Barko loader for logging. All timber is hand felled. Handling equipment includes primarily an IH 3850 wheel loader w/ forks. Also have a small JD 350 dozer that doesnt see much use. Mill is a frick 01 handset with 671 detroit power. Also have a sooner or later to be operational (Jeff this is your invitation to help get this thing flying :)) CMC Forestall automatic mill powered by electric fed from a Cat genset. We are happy where we are at with the current mill (frick) but are working toward getting this one operational soon.
Offline SPD748
Re: Iron Inventory
« Reply #477 on: April 16, 2012, 09:28:27 pm »
Frick 0, currently under construction. Six cylinders of SCREAMING Detroit Diesel power. I'm looking at adding a portable bandmill to the mix. You know, the old 'diversify and conquer' or was that divide and conquer?... This Detroit drone has me all confused   :)
Frick 0 Handset - under construction.
410 Deere
Sawing Since 8am
Serving Since 2002
"Some police officers give tickets, some gave all."
Offline jdsawmill
Re: Iron Inventory
« Reply #478 on: April 16, 2012, 10:35:46 pm »
Home built band mill and 2004 8" Peterson swing blade mill.
Duane
Offline hardtailjohn
Re: Iron Inventory
« Reply #479 on: April 16, 2012, 11:42:26 pm »
We just bought a Belsaw M14 from a guy that's had it for the past 43 years. I've wanted one since I was a little kid! I'm headed to pick it up on Friday, and then the questions will start.
John
I'm so far behind, I think I'm ahead!
Saw Anywhere!
