Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Filing depth guages  (Read 2207 times)
Offline ksu_chainsaw
  • KSU Wildcats
Filing depth guages
« on: January 17, 2006, 09:37:29 pm »
Is there a machine out there that will grind the chain rakers down?  I use a Stihl grinder to sharpen my chains, and then every 2-3 sharpenings, I get out the depth guage and hand file the rakers down.  That is getting a little time consuming, as I have been either cutting hedge firewood, or using my 36"bar- lots of rakers.
Charles
Offline Rocky_J
Re: Filing depth guages
« Reply #1 on: January 17, 2006, 10:10:57 pm »
New files work much better than old files. I usually go to Home Depot and pick up two or three 6" files every so often. They are cheap, toss them when they quit cutting. When the rakers need lowering, two swipes on each raker is usually adequate to get them where they need to be. If you are observant and take the same amount off each raker, then stopping to measure each one is usually unneccessary.
Offline tawilson
« Reply #2 on: January 18, 2006, 12:27:43 pm »
Silvey makes one. Baileys' doesn't have it on their site, but you could call, they may have it or can get one.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #3 on: January 18, 2006, 12:57:25 pm »
Can you get a square stone for your grinder to do the rakers ???
Offline Grande Dog
  • Sponsor
    • Bailey's Discount Logging and Forestry Supplies
« Reply #4 on: January 18, 2006, 03:34:47 pm »
We sell the Silvey HDG-6 raker grinder. They sell for $499.95 and are in stock.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #5 on: January 18, 2006, 04:30:10 pm »
I can do rakers with my Oregon 511A
then again, I think a file is a faster way to sharpen a chain, all things considered.
lots of dull bands and chains
Offline Woodhog
« Reply #6 on: January 18, 2006, 06:19:16 pm »
http://www.forestapps.com/pferd/pferdtool.htm
The above link has a tool that takes the rakers down as you file the chain, I ordered one but didnt receive it yet so I dont know if its any good, the idea is great..
I find filing rakers the worst job of my whole logging operation, sometimes I just use my 4 inch  hand grinder and swipe at them....then hold on tight to the saw.,..
Offline Rocky_J
« Reply #7 on: January 18, 2006, 06:51:13 pm »
I was thinking about this thread today. Got a semi-new .325" Carlton chain on my 346XP. Reading the forums the general consensus is that the rakers are a bit high on this chain and they must be lowered pretty much from the first or second sharpening. My experience confirmed this (I've never owned a raker gauge so I couldn't actually measuer them). Grabbed my 6" flat file out it's sleeve in the toolbox and set the saw on the tailgate. About 90 seconds to hit the rakers on the 18 left-hand teeth and another 90 seconds to hit the rakers on the right-hand teeth and I was good to go. My first couple cuts confirmed that the 2 strokes I took on each raker was just about the perfect amount because the saw cut beautifully.
I know many people seem to be afraid of hand files for some reason. They spend hundreds of dollars on machines to grind chains and never bother learning how to hand file. I agree that filing the teeth takes a certain knack, but the only thing you do on rakers is file them down flat and take the same amount off each raker. All I ask is that each of you buy a $3 flat file before investing hundreds of dollars on a special grinder to lower rakers. It's way too simple to require all that expense.
 8)
Offline Corley5
    • Whittaker Farms
« Reply #8 on: January 18, 2006, 07:35:50 pm »
I've always used a file.  Just take the same same amount off each raker by making the same length of file stroke on each one.  I just bought a grinder to do processor chains to speed things up.  It's time consuming to file away frozen mud damage ;) :)
Offline timberjack240
  • show me a man witha timberjack ill show you a rea
« Reply #9 on: January 18, 2006, 07:43:36 pm »
just watch you dont get em to short i know a guy that di that and snapped the end of the crank off thats takes a lot though
Offline Dale Hatfield
  • A plan is a start to a great ending
« Reply #10 on: January 18, 2006, 08:02:21 pm »
Husky sells
a depth gage tool that i really like over others.
Their tool allows the depth gage to be filled per each tooth. Unlike other  tools that take an average of 2 or 3 teeth pending on style of chain you are running.
Its a very  small tool fits in a pocket. Has 2 settings one for soft wood and one for hard wood.
Dale
Chainsaw Carver
Offline wiam
« Reply #11 on: January 18, 2006, 08:16:05 pm »
I'm with the filers. I learned to file in the woods.  Takes time to learn but it is worth it.  I am pretty sure I can file a chain quicker than I could change it, and then it would still need to be ground.
Will
Offline Button
  • I'm a cutter , not a planter.
« Reply #12 on: January 19, 2006, 03:01:46 am »
 I just put on a 1/4 inch wheel. adjust the stop and I know they are all the same height. I measure the rakers with a vernier caliper. Takes a little practice to achieve consistant results. so far it works for me. enjoy
66 timberjack 230
 394xp
 365 special x 2
 woodmaster
 the rabbits may outrun the skidder but the saw will catch up to the tree
Offline Blake22
« Reply #13 on: January 19, 2006, 08:08:55 am »
I've got a toolbox with every gadget made for sharpening (some weren't cheap) but I always use a file on the teeth & the rakers. I wasted a lot of money on all that other crap.
Blake
Offline SawTroll
« Reply #14 on: January 20, 2006, 09:23:31 am »
"Husky sells
Its a very  small tool fits in a pocket. Has 2 settings one for soft wood and one for hard wood...
I agree, that gauge takes the guesswork out of it, but of course it adds a few seconds to the prosess.... :D
One version of it is the combo roller guide/raker guide, and the roller guide also takes the guesswork out of filing the teeth themselves.
Firewood saws: Jonsereds Raket 621 (1970), Husky 353G, Stihl MS361W, Husky 372xpg, New Edition Husky 339xp, Dolmar PS5100SH, New Edition Husky 346xpg, Jonsered 2153WH, Husky 560xpg.
Offline rebocardo
  • Atlanta GA
« Reply #15 on: January 20, 2006, 10:53:52 am »
fwiw
On some chain (72v versions and 91) you really should not file the rakers and on some they can not be filed flat. I learned that the hard way, when reading the Oregon site to find out why the chain cut so poorly after I took the rakers down to the .025 as it said on the box (general instructions I guess).
Offline tony_marks
« Reply #16 on: February 02, 2006, 05:57:29 pm »
getting dept gauges rite is not that easy for me.
 just got thru taking about 10 chains to .25 . i used an feeler gauge and stihl flat file.
  a chain just dont cut smooth if the depths vary even a little.at least thats my experience.
Offline beenthere
  • EIEIO
« Reply #17 on: February 09, 2006, 09:10:44 pm »
Sawtroll
I just picked up one of these Husqvarna combo roller guide/raker guides today, and tried it out tonight on one nearly worn-out Stihl 3/8" chain, but it seemed to work well (after I filed a bit on the guide to get it to fit down on the chain). Also, the individual raker guide seemed to work well too, using a flat file, and didn't take much time. I will try it out tomorrow to see how this chain cuts. I've been satisfied with my hand filing, but was curious what this would do after hearing about it.
Offline Kevin
    • The Milling Masters
« Reply #18 on: February 10, 2006, 07:41:29 am »
The Oregon roller guides are for Oregon chain, the results will be different on other chain.
Offline SawTroll
« Reply #19 on: February 10, 2006, 08:59:27 am »
True, but the blue one can be modified to fit RS/RSC/RM in 3/8".
Another one can probably be modified for RS/RM/RMC in .325 also, but I have not tried that.
Saw Anywhere!
