Get your Forestry Forum Hats while they last!
my guess for what you are going to do is the old Ford style without the mounted solonoid. They used actual bearings instead of bushings on some models and seemed to be indestructable.
.......... or just get a spare end cap for the other end and grind or drill a hole to line up with the bearing there.
That's the problem. Cutting off the nose cone, realigning it and welding it back straight. The tip bushing has proven to be a good enough bearing so reusing it and placing it closer to the housing should not be a problem. I would be more concerned with welding aluminum and making sure things are straight. I may could get away with trying to shim the armature all the way around and then weld it together. Does this sound like a good idea?
....I was not even 4 miles from Mr Hootie yesterday
