Get your Forestry Forum Hats while they last!
We’ll we’ve went to cutting the blade ............... We were able to cut the .042 and .045 with a good pair of tin snips but the .055s are too thick so I take my angle-head grinder and cut them.
I wouldn't do it to one that's just jumped off. Besides, that never happens to me...
When sawing with a WM and you make your first cut then turn 90 degrees and the log wants to turn a little to far raise up the big end of the log and swing the moveable bed rail under the the edge closest to the sawed face and then lower it back down it will usually tip back the other way then if it don't it will when you adjust for the taper on the small end.
Also if you are on the road and your blade tensioner on your WoodMizer will not get tight because it is hot and the fluid is low You can back it off and put a nickle infront of the plunger and get more pressure.
