Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Anyone experiment with alternative energy?  (Read 12862 times)
Online Fla._Deadheader
  • Linda Vista, Costa Rica
Re: Anyone experiment with alternative energy?
« Reply #140 on: February 12, 2007, 08:16:41 pm »
 Have NO idea how an accumulator is constructed. It acts as a "reserve" pressure tank. Still pokin holes in the build, to see what I can figure out.
  Never heard of the swashbuckle plate pump, Bruce.  I'll look into it.
Offline Don_Papenburg
  • I need
« Reply #141 on: February 12, 2007, 09:54:33 pm »
A hyd. accumulator either has a piston witha spring to force oil back out as it overcomes the hyd. press. or it has a a nitrogen charged bag /diaphraminside the tank .
Oil just spinning in a tranny is at 0 psi and it heats up .  Oil in a opencenter type pump is being forced through two gears . so even if it is just dumping out of the pump it has some pressure.
 I don't think that you need a closed center pump or a variable piston or swashplate . just run the gearpump and a hyd motor through a variable valve.
 One other thought get a hydrostatic drive unit  that has the pumpand motor all in one unit .  That will give you the smoothest of all systems that you could put together.
  Look up   Serplus Center   Linclon Ne
Offline Dana
    • Green Leaf Farms
« Reply #142 on: February 13, 2007, 06:43:10 am »
Tom, What Don said is correct. :) The accumulators on the Star of Charlevoix were nitrogen charged. They look very similar to a large oil filter assy with a charge valve on the top. They are installed in line on the pressure side of the system.        If you think of a  newer water well pressure tank like Well Xtroll  you basically have an accumulator.
« Reply #143 on: February 13, 2007, 07:09:23 am »
 I already been to Surplus Center.  All I could find was transaxle hydrostatic. They did youster have accumulators , also  ::) ::)
  Tha transaxle will have spiders, no ??  Maybe I need to search for exploded view of a transaxle ???  My Bike will have a final drive gearbox, that is inside the real wheel hub. I just have to connect a Hyd motor to the splided driveshaft.
Offline BBTom
  • Making a living helping others. It's a great life.
    • Maplewood Farm Syrup and Craft
« Reply #144 on: February 13, 2007, 07:14:59 am »
I thought most of the newer garden tractor transaxles were hydrostatic.  They would have the right HP requirements for you, but not the right gearing for "road speed".
There are quite a few ATV's with "automatic" drives, and they would be much closer to what you are looking for,  Maybe find a wrecked Polaris ranger, I don't know if the tranny can be disassociated from the engine on those.
better yet, a Kubota RTV.  already have the deisel engine and the tranny.  Kubota Specs link
2001 LT40HDD42RA with lubemizer, debarker, laser, accuset. Full time sawyer since Jan 2002.
Offline Minnesota_boy
  • Some like 'em short, but I prefer looong!
« Reply #145 on: February 13, 2007, 09:28:23 am »
Yup, the transaxle will have spiders.  A transaxle incorporates a hydrostatic transmission, differential and rear axle.  It might work OK for a 3 wheel motorcycle, but I think it might be tough making it work for a 2 wheel motorcycle.
The ones I worked on had a variable volume pump controlled by a swash plate that fed a hydraulic motor that drove the pinion.
« Reply #146 on: February 13, 2007, 09:53:33 am »
 This is the rear "Clip" I will be using. It shows gearbox, brake caliper and rotor, and drive shaft. It swivels on the mail frame, to obtain a "softer" ride. I got a wheel and tire with it, and it's all BRAND NEW.
« Reply #147 on: February 14, 2007, 02:23:58 pm »
Well, that probably explains why mine didn't work.  If figured that it needed some kind of mechanical device to allow for expansion/compression since oil doesn't compress.
« Reply #148 on: February 17, 2007, 12:18:03 pm »
 Just found an interesting Site HERE
Offline Mooseherder
« Reply #149 on: June 23, 2007, 09:05:13 am »
This guy shows how he discovered you can power a sterling type engine using salt water. Interesting Video clip from their local news station at the bottom of story shows how he did it.
I sent this to folks in my e-mail circle and two responded back saying big oil will buy this and squash it. >:(
http://www.wkyc.com/news/news_article.aspx?storyid=68227
Lane Circle Mill Project
Online Ron Wenrich
« Reply #150 on: June 23, 2007, 09:53:28 am »
So how much energy does it take to make the radio waves?
Offline Don P
    • Calculator Index
« Reply #151 on: June 24, 2007, 08:39:28 am »
A high frequency glue machine sends radio waves into one plate, through the gluelines in a panel and to ground in the top plate. They can excite and vaporize the water out of the glue in half a minute or so. 15-20 kw and I don't think there was enough splitting of molecules to run an engine. There was enough electricity used to run one  ???
Offline clousert
    • Clouser Farm - Lion Country Bandsaws
« Reply #152 on: February 10, 2008, 02:21:04 pm »
I make biodiesel from used vegetable oil in our area.  My cost is about $1.10 per gallon (not counting labor, of course).  I have run it in my farm tractors for 2 years.  I like it so much that I'm converting my bandsaw to a diesel engine, and I'll saw with it too.
I made a Savonius style windmill, which really didn't work at all.  Anybody thinking about Savonius style windmill, give me a holler.  If I get around to building another one, it will be the conventional type.
I would also like to hear from someone who made an electric tractor, or car, or go-cart of any kind.  I have an interest in making one of these ever since I saw the electric tractor this fall at the Nittany Antique Machinery Show in central PA.  That thing was awesome!
Tom Clouser, farmer and sawmill operator in Pennsylvania, partner of CLOUSER FARM ENTERPRISES
Offline OneWithWood
  • Board Moderator
  • showing the past to the future
    • RWT Biodiesel
« Reply #153 on: February 11, 2008, 02:20:47 pm »
Hey, Clousert, what type of a rig are you using to make the bio diesel?
Are you using sodium or potasium hydroxide?
How are you handling the glycerol and wash water?
One With Wood
www.rwtbiodiesel.com
Offline clousert
« Reply #154 on: February 11, 2008, 03:19:57 pm »
To OneWithWood:  We had the local welding shop weld a metal cone onto the bottom of a 55 gallon drum, and put the whole thing on legs.  A water heater electrode and thermostat are mounted in the cone.  That is my reactor.  After that I have 2 more flat bottom barrels, in series.
I use sodium hydroxide, the standard household lye, except I purchase it in 50-lb. bags.
Glycerine is drained off the cone bottom reactor about 6 to 12 hours after conversion.  Fuel is pumped into next barrel for settling, (24 hours) and to the fuel barrel after that, also with a bottom drain.  My barrels are equipped with a bottom tap (stove boiler drain) and another tap about one-third the way up.  Barrels are never completely empty, as I only use fuel from the high taps.
Glycerine is just hand-dumped into a storage barrel.  What I don't use as liquid soap, I dump onto a big manure compost pile.
I made 2 batches of homemade bar soap, which worked OK for man-soap, but the women in my house won't touch it.
My dad wants to make a burner to utilize the glycerine better.  It burns well when hot.  In my one soap batch, I was bringing a kettle of glycerine to near-boiling on the stove, and caught the entire pan on fire!
Saw Anywhere!
