Harold,
Any wood that is in the log form is slow to dry. There will be more moisture in the lumber you create than if it had been drying in board form all this time. If it's Southern Red or Eastern Red Cedar you have two things going for you. One is that the wood is quite stable. I've used it with little air drying and it was acceptable. The other is that it will have dried some in the log form so the lumber should not be as wet as it would have been green.
The downside is that the white sapwood may have yellowed and not be as contrasty white with the red heartwood as it would have been if it were cut fresh. Also, Cedar is one of those woods that dulls a blade quickly but is soft enough to still be sawn with the dull blade. You will have to pay special attention to your blades and not over extend them. They will be going through some of the same stresses as if you were cutting a harder wood, you just won't be as aware of it. Pick a time to change blades. If you are sawing steadily, change at 3 or 4 hours whether you feel the need to or not. Be on the lookout for deviations. If the blade starts having trouble cutting knots, take it off. This will allow you to sharpen that blade and get some life out of it rather than using it all up on its first trip.
Sticker the cedar the same as you would any lumber. A meter will probably tell you that it can be used in 5 or 6 weeks. Lots of folks don't wait that long.
Oh! treat it gently. Discourage folks from throwing the boards on the stack or banging them too hard on the mill. The wood is a bit brittle and will split if mishandled.
