« on: December 04, 2005, 12:03:58 pm »
I have XP-1000, 1020 series saws. They have the threaded type spiders.
Replacement Drums/clutches from Oregon are available according to
part numbers but they are slightly different that the OEM Homelite drums.
The origional Homelite Drums had a inner race (cylindrical part) that slides
over the crank shaft. The Oregon parts just have a needle bearing that
rides directly on the crankshaft with no separate inner race.
My question is will those oregon drums work? Reason for the question
is I think the clutch spider threads until it stops on that "inner" race
on the origional Homelite parts and with the oregon that would bind up
that drum unless you use a thinner thrust washer between the clutch
drum and the oil pump. That would allow the spider to stop when it runs out
of threads on the crank shaft.....is that OK??? My instincts are that's
not the right way but the parts numbers provided by oregon only have
drums without that inner race.
Whats your opinion?
Logged
Husqvarna 365/372 Blend, 365SP, 268 WJL, 266se/272 blend, 272XP, 272XP MotoM, 61/272XP WJL Blend, 351 MotoM, 455, 238 WJL, 440e, Homelite Two S-XL 925's, XP-1020A, Jonsered 2094, Three 920's, CS-2172, 2040/Craftsman46cc Blend, 2051, 49sp, 621
